Question about Samsung DV330AEB Dryer
Samsung clothes dryer stuck in cooling mode - Samsung DV330AEB Dryer
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
I have a Samsung DV431AGP. Dryer never stops clothes are done and just keeps running. Even in the timed mode. Starts up, drys clothes, and 1 hour later still has same amount of minutes left.
the cause of this is a bad timer switch it is the switch directly under the knob you turn to set the time on the dryer.You can purchase a new one on amazon or buy one from tribbles in timonium.
Sep 16, 2013 | Samsung Dryers
Duet dryer on sensing mode>what does that mean
The "Sensing Mode" occurs when the dryer is trying to detecting the dampness of the clothes in the dryer to determine if they are dry or not.
If the dryer is "stuck" in sensing mode - there is a problem that should be checked.
Sep 06, 2011 | Whirlpool Dryers
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Dryers
2 yr old samsung dryer does not dry clothes totally
Remove the vent completely and clean it out 100 percent. Elbows (corner bends) will hold more than you think causing the dryer to keep the heat off. The sensors for the newer style dryers detect plugged up vents and shut down the heating modes. If cleaned and still no heat the spark ignitor has gone bad
Apr 07, 2010 | Samsung DV218AG Gas Dryer
Dryer will not dry cloths
make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Apr 18, 2008 | Whirlpool LGR7646E Dryer
Samsung DV330AEB Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
