Question about Raypak Rp2100 Pool Heater Rocker Switch Spst 006872f
Which way does the rocker switch need to be - Raypak Rp2100 Pool Heater Rocker Switch Spst 006872f
    Top Expert:
  • Raypak Master
  • 5,953 Answers
Get ohm meter check to see if closing or jump to test
Posted on May 14, 2016
I took the front panel off to paint it and I need to know how the 3 wires on the rocker switch go back on.there are 3 wires that go on the rocker switch there is 2 orange/2 blue/1 black
There are a lot of devices with rocker switches, what is it. You say there are three yet you enumerate five wires??? If I don't get back somebody else could.
Jan 24, 2014 | Electrical Supplies
P 2647"A" Rocker Arm Actuator
Your going to need a air pressure regulator or better yet if the ECM found fault price it and replace it
  1. Start the engine, and let it run for 5 minutes, then turn the ignition switch to LOCK (0).
  2. Remove the cylinder head cover.
  3. Set the No. 1 piston at top dead center (TDC).
  4. Move the intake secondary rocker arm A for the No. 1 cylinder. The secondary rocker arm A should move independently of the secondary rocker arm B.
    1. If the intake secondary rocker arm A moves freely, go to step 5.
    2. If the intake secondary rocker arm A does not move, remove the secondary rocker arms as an assembly, then check that the pistons in the secondary rocker arms move smoothly. If any rocker arm needs replacing, replace the secondary rocker arms as an assembly, then retest.
    3. Repeat step 4 on the remaining intake secondary rocker arms with each piston at TDC. When all the secondary rocker arms pass the test, go to step 6.
    4. Check that the air pressure on the shop air compressor gauge indicates over 400 kPa (4.0 kgf/cm2, 57 psi).
    5. Inspect the valve clearance.
    6. Install a 10 x 1.0 mm adapter to the inspection hole, then connect the air pressure regulator
  5. With the specified air pressure applied, move the intake secondary rocker arm A for the No. 1 cylinder. The secondary rocker arm A and secondary rocker arm B should move together. If the intake secondary rocker arm A does not move, remove the secondary rocker arms as an assembly, and check that the pistons in the secondary rocker arms move smoothly. If any rocker arm needs replacing, replace the secondary rocker arms as an assembly, then retest.
Aug 23, 2011 | Honda Accord Cars & Trucks
I need to find leviton 1755 in brown
You could use 3 brown single-pole despard switches
Otherwise I cannot find source for triple rocker in brown.
Apr 30, 2011 | Leviton 1755 Triple Rocker Switch Decora
How do i use the primer rocker switch
A rocker switch is an on/off switch that rocks (rather than trips) when pressed, which means one side of the switch is raised while the other side is depressed much like a rocking horse rocks back and forth. A rocker switch may have a circle (for "on") on one end and a horizontal dash or line (for "off") on the other to let the user known if the device is on or off. Rocker switches are used in surge protector s, display monitors, computer power supplies, and many other devices and applications.
A rocker switch with independent circuitry can have a light activated on the face of the switch in both the on and off positions, which allows the switch to be found easily in the dark. With dependent circuitry, the light is activated only when the switch is on.
Jan 13, 2011 | General Electrical Supplies
Great Little heater: I need the Off-On Rocker Switch
go to radio they have many diffrent rocker switches if you cant find it there then call me 985 210 7291 i will get you one cheep ok jason
Apr 09, 2010 | Vornado EH1-0014-01 Compact Heater
The rocker switch on the touchpad is not working and i can't seem to find how to set it.
The Rocker Switch is not active by default. You will first need to assign and action to it for it to function. To assign and action to the rocker switch do the following:
  • Go into the Control panel (Click Start -> Control Panel in Windows XP)
  • If you have not already then you will need to change your control panel view to "Classic View".
  • In the Control Panel list, double click on MOUSE.
  • While in the Mouse Properties click on the 'Advanced Features Tab"
  • Click on 'Settings"
  • To set the Rocker Switch click on the + by 'Button' and choose to action you would like to assign to the Rocker Switch.
  • Click OK
Dec 30, 2009 | Gateway 450ROG Notebook
Need to remove rocker switchs on my roadglide so i can paint inter fairing parts
Rocker switches usually just pop in and out. gently try to raise the metal frame around the switch top or bottom first
Oct 27, 2009 | 2000 Harley Davidson FLTR-FLTRI Road Glide
Replace switch on electrolux 2100
The 2100 is an older model which is prone to rocker switch failure. What you see outside is only a switch button. Underneath is a plastic rocker which sits in a grove and pivots back and forth to activate the on off switch.
If you push the switch down and there is no audible "click" you Likely need the rocker itself, especially if you tip the vac upside down and shake it and hear a piece rattling inside or find a broken narrow plastic finger about 1/2" inch long when opened.
However if it clicks and works every 3-5 times,the rocker is fine and you will need the spring mechanism and switch button which you can see form outside.
To remove either the process is the same.
Separate the body by opening the bag cage and pulling the two bumpers forward with a set of pliers. They are locking keys. Once removed, the rear housing will drop off allowing the vac to hinge open back to front. Do this with the vac laying upside down and observe the hinge section of the front bag door .DO NOT REMOVE THE MOTOR. You will need to clip all these componnets back together to reassemble and slide the bag chamber back to seat against the motor with the motor housing engage in the ribbing of the vac side walls.
With the vac open you will only need to remove the spring loaded bag lockout switch and the bag housing it sits on, not the motor or rewind..
Once removed there will be 6 chrome philips screws visible. These hold the top trim on the front of the vac and the front ones hold the on off switch into its housing. At the very front will be two screws going through a black or whitish switch housing. That housing will lift out with wires attached to reveal the switch rocker, etc,. This portion will lift back and out at about 45 degrees of the inner housing, as a unit. The switch button sits atop the rocker via two end tabs and will pop off the housing to reveal if the rocker itself has a broken "finger" or if the button has a weak spring.
The suspect spring is not the coil rocker spring but the thin U shaped spring on the underside of the switch button. Remove the rocker spring with a pair of needle nose pliers.and examine the rocker comparing to your new one.Use more vaseline on the new rocker and if you have it reinsert the clear flex plastic into the coil spring. If not disregard.
Re-installation is the reverse order, tuck switch back in at 45 degrees from back to front.
Pay special attention the the rubber seal at the back of the bag cage.
If anything is misaligned in this body you will fight to reassemble. Don't fight it , back up and look at your work. When and ONLY when it is perfect it will realign and click together like a lego set and the keys will slide in perfectly
You can and should test the vac before reassembling the whole body, simpley slide your hand under neath and activate the switch, with a bag inside the vac.
See now, wasn't that EASY???????
Please post back to advise how you make out. Its a 7 minute process worth $25 for a good tech. A bad tech will spend half a day trying to figure this one out but just go slow and follow the instructions and you will do fine.
Oct 17, 2009 | Electrolux UltraLux 2000 Bagged Canister...
How do you adjust the clock on a porsche cayenne s 2005
Hi, British Summer time hey! You can use the indicator stalk to access to menu.
Navigate your way to settings, the select the Clock option and set the time using the ricker switch, you can also format the clock to 12 /24 hour - enjoy!
Bash.
Apr 14, 2009 | 2005 Porsche Cayenne
Rocker switch for 600 watts broken----
First of all complaining to FixYa isn't going to accomplish anything. I doubt that the supplier of your device even knows about FixYa. Now on to your problem --- can you get me any numbers off the rocker switch? I'll do the research and get back to you. Use my original email address which can be found in my profile.
Dec 01, 2007 | Lakewood Oil-Filled Electric Radiator...
Raypak Rp2100 Pool Heater Rocker Switch Spst 006872f Logo
35 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
