Question about GE Cafe Dishwasher. Built-In Tall Tub Dishwasher in Stainless Steel
Ge cafe dishwasher making high pitch noise - GE Cafe Dishwasher. Built-In Tall Tub Dishwasher in Stainless Steel
SOURCE: Dishwasher noise
see the fix at the following link:http://www.fixya.com/support/t204050-ge_adorda_dishwasher Simply zip tie the water tube for the middle spray to the upper basket.......it works!
Posted on Sep 05, 2008
  • 81 Answers
SOURCE: electricity went out last night. when i get up
The electricity probably "surged" when the power came back on. It sounds lke the conrol board may have "fried". Call the repairman and get an estimate.
Posted on Apr 24, 2009
localwonder
  • 6784 Answers
SOURCE: Power outage occurred. Upon power back on Dishwasher has high pitch tone and no lights and it will not do anything but make sound.
A power surge has occurred unfortunately. this surge has fried the control module and, you will need to replace this module asap.
I would check the motor as well. it may have took a hit as well. test the continuity of the element as well.
Posted on Jun 03, 2009
  • 70 Answers
SOURCE: My GE 500 dishwasher is making a high pitch noise.
pump running dry(without water)
1)check the water hose connected to the machine(solenoid filter block)
Posted on Jan 08, 2010
SOURCE: Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Posted on Jan 27, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
I have a newer model GE dishwasher. About a couple of weeks ago we lost power to home. When power was returned the dishwasher was making a high pitch sound and power was not returned to the front...
Hello
High pitch sound comes when the main control also known as the electronic board goes bad and needs replacement. Please try to blow air with hair dryer on the display just to check if that'll solve the problem. Hope you understand...If it does not then replacement of part is only recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
My GE 500 dishwasher is making a high pitch noise. There is also no water in the bottom of the dishwasher. I think it might be the water pump.
Jan 07, 2010 | GE Dishwashers
High pitched noise
Then you will need to stop the fan and see if the noise is still there. If yes then its in the compressor. If it goes away then replace the fan
Sep 08, 2009 | GE Refrigerators
Electricity went out last night. when i get up this morning, it is making a high pitch squeeling noise and now none of the buttons work????? its a ge profile dishwasher
Mar 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
GE Cafe Dishwasher. Built-In Tall Tub Dishwasher in Stainless Steel Logo
222 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
