Question about Tomtom tom ONE V2 (Edition 2), ONE V3 (edition 3)
Does my tom tom 2 have a battery that can be replaced or is it toast?
Tom tom dont want to turn on
Did it overheat? or is just the battery dead?
If the LED, comes on, when you connect it to the power, even when the battery is bad, the tom-tom should start working, when you press the power button. Make sure it is getting power. If that does not work, perhaps you should replace the battery.
Feb 11, 2014 | Tomtom Tom XL 325 330 330S 340 340S GPS
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
I used my tom tom cig lighter power cord to power
I think it destroy. The tom tom might of use to much power, and toasted the nuvi.
Nov 21, 2009 | Garmin GPS
I am having problem with my tom tom one xl it has frozen up it will not switch on or off only by by using the reset button and thats all it will do cannot get it to activate any thing else, many thanks,
you need to download tomtom2.gif home from the tomtom site so you can get the update for your XL. this normally cures the problem and tomtom home will do it almost automatically.
just choose your operating system, then after you run it on your computer, just follow the on screen instructions.
Oct 17, 2009 | Tomtom GO GPS Receiver
TOM TOM IS NOT CHARGING
if it is not charging the cause is the batteries need replacing, they last about 2 years
Oct 15, 2009 | Tomtom ONE GPS Receiver
Tom tom 920T need to swop battery ?
You need to have a special tools!
Torx T7 and small flat head !
On the back of unit, using torx unscrew 2 screws!
Using small flat head screwdriver pick the front panel!
Carefully disconnect cables on the back of the display!
Unscrew circuit board!!!
Carefully disconnect speaker wire, and battery wire!!!!
Battery is glued to circuit board, carefully pill it off!!!!!!!
Place new battery on the same spot, and revert all the directions!!!!
Good Luck!!!!!!
Roman
Aug 07, 2009 | Tomtom GO 920 GPS Receiver
Tom tom not charging up!
Battery's probably dead. If you're within warranty you can have it replaced by contacting TomTom. Otherwise, you can still use the device, you'll just have to have it always connected to the charger.
Dec 20, 2008 | Tomtom ONE 3rd Edition GPS
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
Tom Tom Touch Screen
While l was cleaning my tom tom 300 touch screen, some of the cleaning solution got in between the glass layers and I now have a spot that keeps moving. my question is there any way to open this up and dry this out or is the screen toast. Thanks mukat
Jan 14, 2008 | Tomtom GO 300 GPS Receiver
Tomtom tom ONE V2 (Edition 2), ONE V3 (edition 3) Logo
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
