Question about Epson FX-2190 Dot Matrix Printer
How to i set the ip address....i am setting up a new printer
3 Suggested Answers
SOURCE: I have one Epson TMU220PD
switch on your printer while pressing feed button.printer will print some pages and u can read ip address of printer in printed page.Then add same ip range in ur computer.connect printer to pc by network cable.test ping command to printer ip address.if ping succes then open internet explorer, type printer ip address in address bar, press enter key..there u can set ip adress from tcp ip options.
Posted on Oct 28, 2010
  • 4 Answers
SOURCE: Hi, my computer cannot connect
maybe your network have DHCP server. WHen you set the IP on your printer, please select "specified the IP address, not select use DHCP.
Posted on Mar 18, 2011
Connect fuji xerox printer - mac pro computer as it was
Hi Lindsay. Was the fuji xerox printer plugged into the old modem by a blue ethernet cable ?
When you changed your modem it would have had a device inside it called a dhcp server that allocated the IP addresses to your computers automatically.
Now I suspect that the new modem has a device inside it called a DHCP server that is allocating a different range of IP addresses to your computers from waht it used to be.
Here comes the technical part
On the printer menu screen there should be a network setting option . Take a note of the IP address of the printer it will be 192.168.0.x or 10.0.0.x x being the unknown number. also take a note of the subnet mask . it will most likely be 255.255.255.0
next but I have no idea how to look that up on a MAC IOS system.
you may see the ip address in the printer settings properties in the MAC
you may be able to get your ISP to remotely set up your DHCP server in your router to work in the appropriate ip range to match your printer IP address and to avoid allocating the printers ip address to your computers. Then restart the computers to get new ip addresses.
If you tell them the printers IP address and Subnet mask they should be able to alter the modem's settings DHCP settings for you.
The other option is to get the DCHP IP address range of the modem and subnet mask and change the printers IP address setting and subnet mask to match the DHCP leases range by giving it a much higher number than the computers are most likely to be running on.
so if the range was 10.0.0.1 to 10.0.0.254 with subnet mask of 255.255.255.0 then the printer would be set to 10.0.0.254 and subnet mask 255.255.255.0 The first three left numbers must match they are known as the network component of the ip address 10.0.0.0 or it may be 192.168.0.0 the zero end number is the network address so you can't allocate it to a device. 192.168.0.1 or 10.0.0.1 is usually the modem address.
ISP may be able to guide you how to change the setting on the printer .
I had a client that had a lot of trouble getting a tech to come out and set up their printer to an APPLE system. I was the final Tech that eventually came out and set up the printer .
Feb 17, 2016 | Computers & Internet
Tip
Wireless printer goes offline
Let's set a static IP address for the printer:<br /><br />- Print a Network Config Page from the front of the printer. Note the printer's IP address.<br />- Type that IP address into a browser to reveal the printer's internal settings.<br />- Choose the Networking tab, then Wireless along the left side, then the IPv4 tab.<br />- On this screen you want to set a Manual IP. You need to set an IP address outside the range that the router automatically sets (called the DHCP range). You can change the DHCP range of the router using its internal settings page.<br />- Use 255.255.255.0 for the subnet (unless you know it is different, if so, use that)<br />- Enter your router's IP (on the Network Config Page) for the gateway and first DNS. Leave the second one blank.<br />- Click 'Apply'.<br /><br />Now, shut down the router and printer, start the router, wait, then start the printer.<br /><br />After this you may need to redo 'Add a Printer' using the new IP address.
on Apr 02, 2011 | Office Equipment & Supplies
Tip
Getting 169.xxx.xxx IP address of the printer on wireles network
IP address 169.xxx.xxx is invalid IP over the network<br /><br />Go to printer front panel<br />restore network defaults<br /><br />restart printer<br />go back to front panel<br />look for printer wireless network settings<br />print configuration or network page to check if printer will have 000.000.000 IP address which should be<br />if it is then run the wireless set up wizard to connect the printer again over the network and get new IP address<br /><br />If doing above doesnt fix the issue<br /><br />Go to printer front panel<br /> restore network defaults<br /> <br /> restart printer<br /> go back to front panel<br /> look for printer wireless network settings<br /> print configuration or network page to check if printer will have 000.000.000 IP address which should be<br />turn off the router<br />turn off the PC<br />turn off the printer<br /><br /><br />then do sequencial rebooting<br /><br />How?<br /><br />1. Turn on the router<br />2. Turn on the printer<br />3. Turn on the pc<br /><br />check the wireless settings of the printer and new IP address should be given this time it should be valid one<br /><br /><br />Why?<br />by turning on the printer first router will give the very first IP address to the printer before PC huge chances for the printer to get valid IP will be possible<br /><br /><br />If still unresolved<br />contact network provider to check for security settings of router such as<br />Firewall<br />Mac Filtering<br /><br />Hope I help you a bit.<br /><br /><br /><br />Your's Truly,<br /><br />Christian from HP<br />
on Mar 27, 2011 | Office Equipment & Supplies
Printer lost static IP address with new router and won't install on network.
Your printer is looking for your old router.
Reset the printer:
  • Verify that the printer is powered on.
  • Press and hold down the Report Page button.
  • While holding down the Report Page button, press the Cancel button three times.
  • Release the Report Page button.
Now, re-connect your printer to you new router.
Source :
Re Can Get DeskJet 6840 To Work on Wireless Network Need HP Support...
Feb 12, 2014 | HP DeskJet 6840 InkJet Printer
Hi there,\r\nWe have a Linksys WPS54G print server and I'm trying to re-connect it to the new Veridon Fios router. The print server has a default ip address of IP Address:169.254.53.156 but the new router...
The problem is that your printer can't obtain an IP address from your router so it is kicking back the IP address 169.x.x.x which indicates it can't reach the router. You need to go into the IP address configuration on your printer and set a static IP address on the same subnet as the router. For example your router's IP is 192.168.1.1 so set your printer's IP address to 192.168.1.5 and set the default gateway on the printer to the router's IP address (192.168.1.1) next you need to enter in the DNS Server address which is also the router's IP address (192.168.1.1). Once you do that you will be on the same network as your router. From there you can add the printer on your computer through devices and printers if its a Windows pc. Cheers! J the Guru
Oct 16, 2017 | Linksys Computers & Internet
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
May 06, 2010 | Dell 1720dn Laser Printer
I followed this suggestion and now the IP address is 0.0.0.0. I can not get to the printer setting. I don't know if the DHCP setting still remained as static instead of dynamic. ANY SUGGESTION?
I had the same problem, after removing the DHCP settings, maybe for an error during the configuration the printer didn't assume the new IP address and it resulted 0.0.0.0 from the configuration page.
No way to connect to the printer until I did a network card reset following this procedure:
7. Network Card Reset:
a. Turn the printer off.
b. Open the front cover.
c. Hold down the Continue and the Cancel button while powering the printer on.
d. Release the buttons when the Error light (bottom light) stays on solid.
e. Close the front cover and the printer should return to a READY state.
f. Press and release the continue button to print a network settings page.
g. On the page that prints verify the following:
�� Status = Not Connected
�� Active = Yes
�� DHCP,BOOTP,RARP Enabled = Yes, Yes, Yes
�� Address Source = Manual
�� Address = 0.0.0.0
The printer took a new IP address from the DHCP server.
Since my goal was to set a fixed IP address, I entered the printer configuration through Internet explorer, typing the newly assumed IP address and going to TCP/IP settings where I removed The 'Auto DHCP' and I set the IP address I wanted.
Oct 20, 2008 | Dell 1710n Laser Printer
Router sends my printer invalid ip address
Wow what a mess, this is hard to explain easily?
All network printers should be set to a Static IP address. (Fixed address). Somewhere in your Printers network settings you will find this, it should not be set to DHCP...
Your router is probably set to DHCP, which reassigns all address.
Your computer will send out a communication telling everyone on the network the PCs new address...
Your network printer will not do this.
In your PC in the Print Driver Properties you will see Ports which should have the IP address of your printer, which is a TCP/IP port.
Which will stay the same as when you installed the printer.
When your printer reboots and a new is address assigned if set to DHCP, the pc will still look for the old address, while the printer has a new address.
That is why the printer should have a static IP address assigned from within the machine
The gateway, subnet mask should reflect the same as your network. (The gateway does not have to be in there to work by the way, if you’re using it on the same router)
If you reinstalled the printer after your system rebooted, you probably have the printer installed more than once.
If you do not set the printer to a static IP address this probably will happen again when it is restarted or there is a loss of electricity.
Hooking a patch cable directly from your PC to Your printer will not work; it will work with a crossover cable and a few minor changes to the settings.
USB and Network use different protocols. TCP/IP uses a completely different addressing system.
I don’t think your problem was with your network, as much as it is with the Static address of the printer.
If it is printing for you now the easiest thing to do here to prevent future hassle...
print the network settings
go into your printers IP Networking settings and set the IP address and Subnet as what the printed page is ( I usually turn off DHCP, IPV4, IPV6, NetBIOS etc, and only have tcp/ip on, if your machine offers this?)
Good Luck
Sep 19, 2008 | Sharp (AR-NB2N) (ARNB2N) Print Server
About n/w printer
If you have the network enabled 1022 you need to find out it's current IP address. To do this press & hold the Go button on the top of the printer (the large button) for 5 - 10 seconds or until the printer starts to print. This prints out the configuration page.
The printer is set to get an IP address via DHCP from the factory, but once you have it's IP address you need to give it a static IP address. You can do this by typing the IP address into a web browser & go to the network tab. choose an IP address that has not been allocated already & apply the changes.
You will need to type the new IP address into the browser if you want access to change further settings.
You can then add the printer using the new static IP address.
Sep 16, 2008 | HP LaserJet 1022 Printer
Printer unable to obtain IP address
Reset the TCP/IP information. To do so, Turn off the printer power. With the cartridge door open, hold down both cancel and continue buttons and power the printer on. Hold the buttons until the lights cycle. The TCP/IP information should be cleared. Wait a few minutes.The printer should pick up a new IP address from the network, or should set a default IP. Press the Continue button to print a new test page, and you should see the new address.
Mar 24, 2008 | Dell 1710n Laser Printer
Epson FX-2190 Dot Matrix Printer Logo
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
