Wiring candy cti653t - Washing Machines
Help fix cotton candy machine
The lighter wires from the transformer, black attaches to terminal 4, (this will have many other wires attached, and can be more than one terminal labeled #4) The red from transformer attaches to #3, it will be the only wire on a #3 terminal.
The heavier red wire most likely goes thru the back wall to the brushes, and attaches to a #4 terminal also. They have used different heat controls over the years, so this diagram may not exactly match your machine, the the terminal numbers are consistant.
May 17, 2013 | Kitchen Appliances - Others
Candy DWI 160 dishwasher water not heating.
the only things is the TIMER: CAN BE FAULTY, maybe is stuck, not completely the cycle.
Clean the contact with special spray, loose the wires, replace burn wires, or break wires.
May 08, 2012 | Candy Dishwashers
My skull candy lowride jack has a lose wire how do i reapir it? plz help
It's probably easier to buy a new jack from an electronics supply store.
Cut the old one off and strip the ends of the wires.
Solder the wires onto the new jack. It might take a little time figuring out which wire is which.
Don't forget to put the jack cover on the wire before you start soldering.
Jan 28, 2011 | Skull Candy Lowrider Headphones
I need to replace plug on my skull candy smokin buds
the copper wires both go to the common/ground of the plug. those wires both connect to the contact that is closest to the cable. the other two connect to the other 2 contacts just pick either or.
Oct 08, 2009 | Skull Candy Smokin' Buds Headphones
CANDY TUMBLE BRYER BELT
i changed the belt on my candy civ 100 but it wont turn on yet all the wires seem to be connected and the fuse in the plug is ok
Apr 25, 2009 | Candy Dryers
Candy CS 455 M fault
Request the wiring diagram you need directly from Candy.
Dec 17, 2017 | Candy 17 in. CS455 Built-in Dishwasher
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
