Question about Yard Machines MTD Gold 20 HP Lawn Tractor 13AL795T004
I have a yard machne mtd 46 in cut where do i put the pto spring engage back on mower deck
I took the deck off, and now I can not remember where the pto engage sping goes. model numb. 13rn771h729. yr. 2007
  • 12113 Answers
SOURCE: I bought a yard machine mower last spring.It fails
check air filter and plug -if good than carb needs cleaning or repair
Posted on May 06, 2010
SOURCE: my yard machine 14.5 hp briggs engine with 42
It’s a bad solenoid. Mine was located under the shifter plate?
Posted on Aug 08, 2010
  • 760 Answers
SOURCE: Can I replace the blades on my 38in MTD/Yard
If its in good condition you might be able to but be careful so mower doesn't fall on you. I've used my car ramps and backed the mower up the ramp and was able to do it safely. If you have any difficulty removing the blades, then I'd take the deck off. It really isn't that hard to remove the deck.
Posted on Oct 04, 2010
  • 599 Answers
SOURCE: I NEED TO LOCATE A DECK FOR A 46" YARD MACHINE
You probably have in your area a number of small engine repair shops. You will have to get on the phone and start calling around for a used mower deck. They usually have many old mowers in there yards. If you decide you only want new it could be very costly. GOOD LUCK.
Posted on Jul 05, 2011
kel1guy2002
  • 3740 Answers
SOURCE: My MTD yard machine blade stopped engaging I found
Hi Richard,
I see I am late responding to this but I now live overseas and it is 6 am here. I note you have already taken the unit in for repair.
I ws just trying to sort out which spring and clip had departed from your mower knowing the original problem was that the baldes would not engage.
I think but am not positive that your talking about the spring that is item 26 this link:
http://www.partstree.com/parts/?lc=mtd&mn=13AL795T004+%282010%29&dn=769054030013
The clip maybe item 60????
You can look at other diagrams for your mower on this page:
http://www.partstree.com/parts/?lc=mtd&mn=13AL795T004+%282010%29 I looked at the PTO drive but did not see the spring or clip.
When you get it back from the shop could you respond post the location that they installed the spring and clip? Just has the curiousity factor way up here. Per your model number this mower is a 2010 unit and hopefully the problem you had is not one that will keep repeating for other owners.
Thanks and take care,
Kelly
Posted on Aug 12, 2011
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
I have a MTD yardman 1999,2000 ride mower that won't start because it says the pto is engaged when it's not actually engaged if you could comment an image of the same 42 inch deck?
Check your PTO switch operation which is at the engagement handle.
As for hooking the cable spring to deck idler pulley and brake assembly it goes in the hole closest to the idler pulley on the G deck which different then the F deck which uses the same idler arm assembly as the part is design to fit both decks.
Also make sure your using an OEM spec as a will fit will not work properly. You also must the spindle pulleys belt retainer covers in place so the belt will stay on.
May 10, 2015 | Mtd Garden
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
Where do i attach the PTO deck engagement spring on the cutting deck of the 2009 cub cadet LTX 1040 PTO deck engagement cable attachment on the cutting deck
Wherever it was that you took it off from. If it broke, then look to see where a spring might be while you have a friend slowly engage and disengage the assembly. If it's an electric engagement situation, bring it to a shop. If you don't have a friend, sorry. I'll be your friend.
Sep 25, 2014 | Garden
Mtd manual
MTD uses several different configurations. Electric PTO's are tensioned all the time by an idler pulley on a spring loaded bracket. Manual PTO's with an engagement lever have a movable bracket attached to the lever via a cable that will tension the belt when the lever is engaged. Another configuration is the deck engages when the deck is lowered with the deck height lever and disengaged when the deck is raised. In this case the belt is tensioned by a large spring from the rear deck support bracket to a mount on the transaxle and tension is released by a rod that pull the deck forward when it is raised.
Sep 01, 2014 | Garden
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
Aug 14, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard Machines MTD Gold 20 HP Lawn Tractor  13AL795T004 Logo
20 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
