Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars Lite 2 Heaters starts up (ignites) and shuts down in 2 secs
Basically, the fans start spinning, the gas flows, you can hear it light and then it just shuts down. This happened before and my old pool guy replaced the pilot and it worked for a year. My new pool guy cant figure it out. ANYBODY PLEASE HELP!
  • 139 Answers
Usually indicates a flame sensing problem. remove sensor and clean with steel wool .
Posted on Jun 24, 2009
Why won't my Laars Lite 400000 heater light?
should be 24 volts ac tyo the brown and yellow wires to the gas valve at start up or when you hear click
Jun 20, 2012 | Teledyne Laars Laars Lite2 Heater 400000...
I have a laars lite 2 manual controls natural gas. The unit starts up runs strong for 5 mins shuts down restarts runs for now only seconds and shuts off
sounds like the hi limit switch is shutting it down,because it is not getting enough water,cloged filter, valve to heater notopen,bypass valve not closed,open up the water releif valve with the pump running should be alot of water running coming out of it.
Jun 13, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
We have a laars lite 2, when we openned the pool
Thank you for posting your question here on Fixya.com.
It could be...does it open up at the point the heater shuts down? Check it with a DMM to see. It is more likely an issue with flame recognition off the pilot/ignitor. Check them for rust that would cause a faulty connection.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Cannot start teledyne laars pool heater
Hi should be horizontal crack pipe and see if gas is there do this with every thing off then pruge pilot line should have gas then
Jun 26, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
PILOT LIGHT WILL NOT LIGHT
the thermocouple not only keeps the pilot on but lets the gas valve know its okay to open on a call for heat, remove your thermocouple and clean it with a fine grit sandpaper and if this doesn't work replace it all together.
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars lite 2 Spark egnighter will not spark
turn power off first. I would disconnect igniter wire which will be a thick orange wire that comes off of ignition module if it is spark. once you have that the end will look like a spark plug wire take shield away from metal then hold orange wire in hand close but not touching metal turn power on and it will take a couple of minutes before it should start sparking. If you don't see a spark then it is most likely the ignition module. There should be a red light on ignition module that will blink to tell you what the failure is if is is a newer on. When you turn power on to laars light 2 the inducer motor should come on then a pressure switch should send 24volt to gas valve for pilot to lite.Can you smell gas at all when laars should be igniting. If you have any questions fell free to email me back
May 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
272 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
