Question about Health & Beauty
Pulse rate 58 - Health & Beauty
What should pulse rate be for a man 90 years of age
You have a pulse, everyday is a bonus. The more active you are the higher the rate, the more inactive the less.
Jul 10, 2018 | Health & Beauty
Karcher pressure washerk7 85m is pulsating what is the cause of this please
See links and videos
Karcher k7.85 Pressure Washer Pulsing when is not in use - YouTube
2q==? 0:58 https://www.youtube.com/watch?v=R9cAGbtjVE4 Jun 17, 2014 - Uploaded by Valdi w Any ideas ?? Missing: washerk7
Karcher K7.85 Pulsing Problems - YouTube
z? 1:15 https://www.youtube.com/watch?v=QB1rk5zkhjM Jun 11, 2014 - Uploaded by Valdi w 1:12. Karcher k7.85 Pressure Washer Pulsing when is not in use - Duration: 0:58. Valdi w 14,672 views · 0 ... Missing: washerk7
karcher k6.85m pulsing problems , Here's scheme . - YouTube
2q==? 0:50 https://www.youtube.com/watch?v=d8TNOu14gsI Jun 6, 2016 - Uploaded by mihai baciucu PUMP CYLINDER HEAD SCHEME ,I changed myself these valves ,Diagramme n°: 0009 , 0010- ... Comment ... Missing: washerk7
Karcher Pressure wash pulsating! - Page 1 - Bodywork & Detailing ...
https://www.pistonheads.com/gassing/topic.asp?h=0&f=136&t=970368
  1. Cached
Feb 26, 2011 - 17 posts - ‎16 authors I have a small Karcher pressure washer that I use to clean the car. It works a treat with plently of pressure, however, as soon as I let go of the ... More results from www.pistonheads.com Missing: washerk7
Karcher K2 Pressure Washer - pulsing problem ' Screwfix Community ...
https://community.screwfix.com > ... > Landscaping and Outdoors
  1. Cached
Mar 21, 2017 - I have a K2 Karcher pressure washer [IMG] I've added a video, although its not ... Karcher k7.85 Pressure Washer Pulsing when is not in use. Missing: washerk7
Karcher pressure washerk7 85m is pulsating Google Search
Jun 08, 2018 | Karcher Garden
Is there a way to fix the the turn signal chime and other various chimes on a 2009 Chevrolet Cobalt LS, there is no sound from them as well as front speakers?
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the speaker. The radio receives audible warning requests via the serial data circuit. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
May 13, 2016 | 2009 Chevrolet Cobalt
90 300zx fuel pump works its getting spark be injectors wont open what can be the problem?
Possibly a computer (ECCS control unit) malfunction, but first check the white/black wire going to each injector. All should have power on them with ignition key in on. This white/black wire comes from the computer's pin # 58, then is spliced to all 6 injectors. If no power to injectors, check the wire continuity from the ECCS' #58 pin to the injectors.
The ground wire from each injector also goes into the control unit, but individually, so that the control unit may ground the injector circuit and cause pulse.
If the wiring is good, no breaks or shorts, it may be a computer malfunction, but first find out if the variable valve timing affects injector pulsing. I don't know anything about it, but you have 2 VTC (valve timing control) solenoids, one for each side of the engine. Both are located near or on the firewall behind the engine, near the middle. Looks like 3 solenoids there, the middle one is the EGR solenoid, and the VTC solenoids are on each side of the EGR solenoid. Best I can do from a very poor wiring diagram I was looking at.
You checked for spark, but did you check on all six plugs for spark?
Apr 08, 2015 | 1990 Nissan 300ZX
Sys 154 dia 93 pulse 125
Your blood pressure rises with each heartbeat and falls when your heart relaxes between beats. While BP can change from minute to minute with changes in posture, exercise, stress or sleep, it should normally be less than 120/80 mm Hg (less than 120 systolic AND less than 80 diastolic) for an adult age 20 or over.
The normal pulse for healthy adults ranges from 60 to 100 beats per minute. The pulse rate may fluctuate and increase with exercise, illness, injury, and emotions. Females ages 12 and older, in general, tend to have faster heart rates than do males.
Mar 01, 2015 | Cars & Trucks
I'm a 53 year old lady and my b.p is 137/86 polse62 to 142/86 pulse 58 along with a head ace is the bp a normal
Normal nib pis 120/80 for normal weight and size. Pulse standing still is around 70bpm. These are ideal values though. Doctor or nurse can adjust for your variables though.
Oct 03, 2014 | Health & Beauty
Why would your pulse rate be over 100
There are many reasons for a high pulse rate. Your pulse rate is the same as your heart rate. A common cause is anxiety. A heart rate over 100 is called sinus tachycardia . Sometimes bearing down as if you are having a BM will "reset" the heart. to normal sinus. It is related to vagal nerve stimulus. An obvious reason for increased heart rate would be physical exertion/exercise. Some medications may also cause an increase in heart rate. Sinus medications have been known to cause this. Too much caffeine will also increase the pulse.
There is also a condition called atrial fibrillation or A-fib. If your heart/pulse rate is not beating in a regular rhythm, it may be a-fib and must be evaluated. In any case, if your pulse rate is consistantly above 100/min you should see a cardiologist to determine the cause.
Sep 10, 2013 | Health & Beauty
I doubt in correctness of reading,my age 58
If you are doubting the Blood Pressure and Pulse readings, there must be a reason for these doubts. But, you failed to explain why you doubted it. Does the BP reading seem unusually high or low? Is the pulse rate, what you expected it to be? Keep in mind, age doesn't always play a huge role in hypertension. It's your general overall health, eating habits, smoking, drinking, etc. In other words, you overall life style, as well as your family's medical history.
These wrist monitors are fairly accurate if applied to the wrist correctly, you keep your wrist at heart level and you don't move during the time that monitor is operating.
If you have doubts, take the monitor with you to your next doctor's appointment. They will probably check your BP with an arm cuff. After they do that, use your wrist monitor correctly and compare it to what the reading was with the doctor's reading. One or two points difference is not a big deal. More than that is.
Hope this helps.
Feb 22, 2011 | Samsung BW325S Digital Wrist Blood...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
