Question about Dimplex Heating & Cooling
Dimplex girona panel heater not heating, red flashing light instead of solid red indicator!!!
4 Suggested Answers
  • 111 Answers
SOURCE: heater does not heat when turned on
check oil overtemp senser or heating element, some of the newer ones have a circuit board with default codes, check for codes,unplug, plug back in and see if it works
Posted on Jan 31, 2010
  • 90 Answers
SOURCE: what does it mean when the power light (the small
was reading a rinnai pdf today about this, green means that the unit has power the red means the burner is operating so it just tells you when the gas is going basically, may not be the same for this rinnai model but is on the energy saver 556 so hopefully that explains your heater for you it should be in the owners manual if you have one as pdf i was reading was manual for another rinnai if you don't have a manual you can try downloading just type heater name and model into your google search with manual mentioned there too should bring up a pdf or a link to manual
Posted on Nov 19, 2010
SOURCE: My Dimplex freestanding electric fireplace, model
Heater keeps turning off and on every few seconds
Posted on Jan 06, 2011
Dualit Toaster on light blinks
Most of the time it is indicating something is wrong. What? could be a thermostat, an overheating sensor, bad cabling inside, or just the element.
Mar 10, 2015 | Dualit Kitchen Appliances - Others
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
Dimplex cadiz eco 3kw not working
I have just got a CDE3ECC and I had the same problem with it power light on no heat.
I took off the side with the timer on and one by one disconnected each connection and took off the brittle heat shrink wrap off the spade connectors and heat shrunk some new sleeving on each spade connector and did it back up and now my heater is working again.
I noticed that the bare spade connectors on the secured down thermocouple was shorting out on the timer panel. (See Image)
New heatshrink sleeving SHOULD cure the problem.
Jan 04, 2013 | Heating & Cooling
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Nov 28, 2012 | Dimplex DS4411 Electric Heater
I have a Kenmore Heating & Cooling System installed 1995. The system light is flashing 3 slow flashes on the curcit board and red on the control panel stating check system. Blower still working and...
3 RED FLASHES: This indicates the normally open pressure switch.. Here is a link it has ac troubleshooting on it,also. Very helpful:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
May 06, 2011 | Heating & Cooling
I have a panasonic th-42pz800a and it wont turn on all that appears is a flashing red light instead of the solid green light next to the button on the tv... any helpers
Flashing red light is an error code, please count how many times red light is flashing after long pause and let me know to diagnose possible cause of problem..
Thanks.
Mar 18, 2011 | Panasonic Televison & Video
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
No Heat or fan on model DS4411 Or 6901050100
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Dec 22, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
264 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
David Burbee
David Burbee
Oloyede Monsuru
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
