Question about Tamron Cameras
How to take apart tamron 18-200mm canon - Tamron Cameras
Can Tamron 2 X converter C-AF 1 BBAR MC-7 mounted with Canon 100-400mm? Tks
As you can read in the Dpreview link the Tamron converter can work perfectly with the Canon cameras. Question is, will AF still work, because you have to multiply the aperture twice. So if your lens has f/1:5,6 that will become f/1:8. Most camera's can't auto focus anymore on F 8
link to Dpreview Tamron 2X converter
Oct 15, 2012 | Tamron F AF TELE-CONVERTER 2X C-AF1 BBAR...
I have a tamron 70-300mm i had a canon 1000d and the lens worked pefectly fine with it but nw i hav purchased canon 550d and when i conect my tamron lens with it , it shows an error 01 please assist me
This is the kind of error which you always risk these days in buying lenses which are not from your camera manufacturer. Error 01 simply means that the camera cannot communicate with the lens. Canon's protocols are not open standards and third party manufacturers have to reverse engineer to produce something which works. As they're working in the dark, they cannot always arrive at a solution which makes all models suit all Canon bodies.
You have two possible solutions:-
Visually inspect the contacts on the lens and the camera body and if they're anything other than clean and bright then use a clean pencil eraser on them. Be very, very, careful not to let any of the rubber crumbs into the lens or the camera body.
If that fails, visit the Tamron website to see whether the lens can be returned to be updated for other bodies. if it can't then sell it and buy a later Tamron model or better still a Canon one. They may cost more, but the results are better and their resale value is much higher.
Mar 07, 2011 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Tamron 28200mm f/3856 LD Aspherical IF LD 138 58
you may find a good camera shop can help you get some replacments for it from there repair chapy,
Oct 17, 2009 | Tamron AF 28-200mm f/3.8-5.6 Di (IF) for...
Get error 99 message
err 99 is moisture or dew inside the camera.
May 07, 2009 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Will not autofocus
Hey shutterbug72,
According to the manufacturer the first thing you should try is cleaning the lens contacts with an eraser. If that doesn't work you could try removing the battery and reinserting it to reset the camera. It seems to me that if there was a compatibility issue going on you should have seen that from the start. As far as what lens you should buy both Tamron and Canon make very good lenses, but with Canon lenses you shouldn't ever have compatibility issues. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 21, 2008 | Tamron 28-200mm f/3.8-5.6 Super II Macro...
Tamron 28-300 mm f/3.5-6.3 LD IF - rear piece broken
Here is Tamron's telephone/fax info;
Tamron USA, Inc.
10 Austin Blvd.
Commack, NY 11725
Phone: 631.858.8400
Toll Free: 800-827-8880
Fax: 631.543.5666
custserv@tamron.com
Apr 05, 2008 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Tamron 28-300 loose lens parts
The way in to this lens is from the rear. You'll need to remove the trim ring inside the mount and free the electronic connector from the mount ring before you remove the mount ring itself.
Jan 19, 2008 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Tamron lens and canon speedlite compatibility
Your question is posted under a Nikon version of this lens. I assume you are talking about using the Canon EOS mount version.
The short answer is: Yes
Jan 15, 2008 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
Cameras Logo
32 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
