Question about KuulAire Humidifiers
How repair kuulaire ka77? - KuulAire Humidifiers
Humidifier light goes on. Fan does not work after cleaning it.
Humidifier Fan Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Humidifier/...---/Humidifier-fa...
Most Frequent Causes for Humidifier fan not working. For the most ... If the fan blade does not spin freely, replace the blower motor. If the fan blade spins freely, ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Aug 14, 2014 - Repair humidifier problems yourself with this expert, step-by-step ...6Lubricate the fan motor bearings with a couple of drops of light oil if the ...
Troubleshoot and Repair a furnace mounted Humidifier
www.instructables.com/.../Troubleshoot-and-Repair-a-furna...
InstructablesThis instructable will explain how to diagnose and, hopefully, repair a broken ... to flow through the water panel of the humidifier and the humidifier fan turns on. .... drain line was dry, GFI was not tripped, and the fan sounded like it was going so I ... Arduino · Intel IoT · Indoor Gardening · Lighting · Sewing · Parties · Star Wars.
Dec 29, 2015 | Holmes Sunbeam SCM3501 Cool Mist Console...
What might be wrong, and is it worth repairing?
I think it is a fairly simple bit of equipment which probably uses a synchronous motor which rarely cause problems, though they sometimes seize and need freeing. Sometimes something might get caught in the fan and stop it.
Whatever is wrong it is clear you can't go any further without taking it apart and maybe checking a few things with a multimeter so if you aren't able to do that it means asking someone else to take a look for you and that someone will want paying even if it becomes an uneconomic repair.
Repair shops want paying these days even for giving an estimate.
My best advice is if you can't do these jobs yourself to start building the sort of circle of friends who are more hands on, who know stuff you don't. Most tradespeople are intelligent, humorous and fun and it is great having them on your side.
My advice doesn't help you now but in the long run it could save you a parcel of money and reduce the amount of planet-destroying stuff you need to throw away.
Jan 26, 2015 | Hunter Fan 34352 3.5gal Humidifer
We had our furnace repair turn on our Aprilaire 760 last summer. It gives off a very strong smell similar to an air freshener. We'd like that to be less in intensity. Furnance company says it's just fine....
I hope this helps you, have the repair person check to see if a furnace filter air freshener was installed at your last furnace check up without your knowledge. Also checked all wall and or floor registers to make sure the source of smell is not coming from them, it may be circulating though the duct system.last thing is to replace media pad in humidifier along with furnace filters, if you have air cleaner wash filters with hot water and baking soda, wipe & let dry before re- installing them. Your repair person may have use a strong smelling cleaning solution in humidifier that is now circulating though out your home, good luck.
Jan 24, 2010 | Aprilaire 700 Humidifier
When I plug the unit in it gives a puff of smoke and kicks my breaker
Sounds like you have a pinched or bare wire inside the unit. If it has louvers for ventilation, I would try this experiment, but just once, and it needs to be at night. Reset the breaker, and get a small flashlight. Go to the unit and get it ready to plug in. Turn off the lights in the room and make sure it is really quiet, use the flashlight to get to the unit and the plug. Looking at the unit, turn off the flashlight and plug it in. You should listen for a crack or pop (the sound of the short) and watch inside the unit for a spark (the location of the short). If my hunch is correct, you will find the problem and be able to repair it. If not, then I would recommend calling out a tech or taking the unit to a repair depot. Good Luck.
Jul 20, 2009 | Whirlpool AD25BBR 25 Pint Per Day...
NEED MOTOR, EATON 416 025 20 FOR SEARS FURNACE HUMIDIFIER
It`s pretty expensive but Appliance Factory Parts has the same motor except at 24 volt and you have to use the gear from your old unit and a step down transformer..as yours is 115 volt..
Around $80 as they will combine the shipping if you call them..
Local electric motor shop repaired my 1994 motor for $35 after I explained to them I could not find a replacement..
I talked to Sears repair service man, he said our units are too expensive to produce today but are better than these new high flow models they use allot of water that just goes down your drain..
Mar 17, 2009 | Humidifiers
Clarion da1030 heating element doesn't work
buy a new one the cost to repair the oldone isnt worth the headache buy new
Jan 18, 2009 | Clarion DA-1030 Humidifier
Aprilaire 700 Humidifier not working. Can it be repaired?
turn the humidistat back up, aand make sure if is still wired up.
Jan 18, 2009 | Aprilaire 700 Humidifier
Membrane on AOS 7135 needs replacement. Is it available?
Customer Questions / Repairs / Warranties / Ordering
Phone 800-336-0326 And the web address is
http://www.airoswiss.net/
some parts available, somethings need to be shipped to them
Jan 08, 2009 | Air-O-Swiss 7133 Humidifier
Won't turn on.
Hi My Unit will not turn on,bought last year,water fill icon flashes but no power.
is there a repair depot on Prince Edward Island? Or how do I get it looked after,
unit brought at Sears. Thanks in advance Norm
Oct 02, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Humidifiers Logo
48 people viewed this question
Top KuulAire Humidifiers Experts
Mack Baxter
Dennis
Are you a KuulAire Humidifier Expert? Answer questions, earn points and help others
