Question about Blodgett Kitchen Ranges
Gas burners on mabe - Blodgett Kitchen Ranges
2 Suggested Answers
bblizard
SOURCE: Mabe Stove Parts
replacement glass top for mabe gas stove top
Posted on Feb 16, 2011
Do the burner control knobs just pull off? Mine refuse to budge.
SYLV,THERE MIGHT BE SET SCREWS HOLDING THE KNOBS ON? CHECK CAREFULLY MABE WITH A FLASH-LIGHT.THANKS
Jan 25, 2016 | Thermador Cooktops
WHATS WRONG WHEN THE GAS DOES NOT COME OUT TO BE IGNITED IN A COLEMAN HEAT AND AIR UNIT.
There are several issues that may cause this. I would have you check that you are getting 24 volts to the gas valve when you call for heating.
Things that may cause you not to have 24 volts:
1. Does the draft inducer motor start when you call for heating?
2. Does the pressure switch close after the draft motor starts?
3. Do you get 24 volts after the pressure switch closes.
4. Are all the limit switches closed? There should be 3 of them one in front of the burners (usually with a manual reset button called a rollout switch), one behind the burners (auto reset) and one in the blower section (auto reset)
Do you have gas to the unit"
Jan 11, 2016 | Coleman 2.5 Ton 13 SEER Complete Split...
Where to buy mabe gas stove burner parts
Not sure what area you live in but check the yellow pages under restaurants/ equipment repair. You will find a local repair company that will sell parts and should be able to help you repair it as well.
Jun 24, 2014 | Blodgett Kitchen Ranges
MABE Stove Manual in English Model : EM6120B2
hello i recently bought a mabe 6 burner gas stove but i need to know the manual is not in english and do i have to plug in before i can turn the gas on? its electronic ignition by the way
thanks
customer
May 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Mabe Stove Parts
Aug 27, 2009 | Blodgett Kitchen Ranges
Im leaking gas into the bar lube area
thats a fuel tank vent mabe replace it.
Mar 17, 2009 | McCulloch Garden
High flame on Mabe Gas Stove
The gas supply pressure could be too high and it could be worth checking or if your supply isn't regulated, try fitting a regulator. Maybe the regulator is faulty if you have one.
From memory I think most domestic gas appliances need a supply pressure of 11 inches on a water manometer. Butane pressures can become quite high in warm weather (and drop to zero at freezing point).
Perhaps your new cooker is jetted for natural gas (methane). As that fuel gas has a lower calorific value than butane the jets would probably be bigger.
As a temporary measure you could try using a hotplate for simmering. I have a gadget that is two sheets of perforated steel with an air gap of about half an inch between them. It is nicely made with a useful handle and a loop for hanging and when placed over a low gas flame it allows me to place the glass coffee pot on it with no chance of damage.
Someone local could surely make you such a gadget if you don't find an everyday item that could be used. A car brake drum would lift your simmering pan a few inches and tend to diffuse the heat...
In the laboratory at school there was an asbestos pad to fit over the bunsen burner so flasks could be heated more gently.
I suggest you take a walk and look around with different eyes to see what you can find...
Mar 25, 2017 | Kitchen Ranges
Mabe gas range
I HAD JUST PURCHASE A MABE 30' GAS FREE STANDING RANGE AT A LOCAL STORE HERE,THE BURNERS WERE ABSENT BUT I WAS ABLE TO SOURCE THEM AT THE MAIN BRANCH,I AM ALL THE WAY IN JAMAICA.I HOPE YOU CAN SOURCE IT,IF NOT FEEL FREE TO LINK ME UP AT fidel_perry28@hotmail.com,i will pass on the relevant info.good luck.
FIDEL
Jul 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Mabe range from mexico, ser # 0304L2100789
100-220 are in celcius and asar means broil. The oven has two burners upper burner for broil and lower burner for baking.
Nov 03, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
15 people viewed this question
Top Blodgett Kitchen Ranges Experts
Gil Shultz
ray gallant
Mister Danger
Are you a Blodgett Kitchen Range Expert? Answer questions, earn points and help others
