Question about Broan-NuTone Kitchen Ranges
Oil leaking front motor - Broan-NuTone Kitchen Ranges
2 Suggested Answers
BCAS1298
  • 3092 Answers
SOURCE: leak oil from front of the motor
CHECK FRONT CRANKSHAFT SEAL.
Posted on Nov 04, 2009
I have a mercedes c230k and 0il is leaking on drive belt and front of motor it's wet and gunk down motor front need to clean to find problem will gunk hurt anything
Any type of oil can cause problems to areas not designed to have oil on lt. Make concern is to repair your oil leak as soon as possible. Sounds like it could be your camshaft front seal. Or a simple valve cover gasket.
Dec 23, 2016 | Mercedes-Benz C-Class Cars & Trucks
I have a massive oil leak
Main source of oil leak is going to be valve cover, crank seal, balance shaft seal and distributor o-ring.
Nov 27, 2015 | 1994 Honda Accord
How to find and repair oil leaks in front of motor?
Ok ralph first off clean motor with engine brite found at any auto parts stores
next recommendation add oil base dye to motor oil allow to run for 30 min to circulate dye useing a uv lamp or black light and inspect front cover most cases the front seal is themost likely source of leaks due to contant revolutions on front main seal
in order to repar suspected seal total dissasembly of timing cover will have to be removed in some models the front main bearing journal will have to be removed as well.
upon removal of timing coverbinspect front mail seal race / face for burnishing of the crank seal face. Dirt an debri cut into the crank
you will have to order the front seal repair kit
consists of front seal and stainless steel wear ring wich is glued in with epoxcy
reassemble front timing cover gaskets an sealer may be needed once all the parts are reassembled run for 15 m7n an check for leaks
its also possible that the oil pan gasket could be leaking as well
install dye to find leak is the best course of action first
Jun 22, 2014 | 2003 Chevrolet Impala
OIL LEAK IN FRONT MOTOR
1st check your oil pan plug. It's one screw underneath the car that is used to drain the oil during changing......next check the oil filter...If its loose, it could be leaking...if not either of these, could be a serious problem........
Jan 21, 2014 | 2003 Kia Sedona
My 88 dodge dakota has a leak between the engine and the transmission. What could the problem be and how can I fix it?
If it is motor oil, it should match the oil on the dipstick.
If it is automatic transmission fluid, it should be sort of redish and match your "tranny" fluid on that dipstick.
If it is thicker than motor oil, it should be manual transmission oil.
Motor oil leaks from the "rear main seal".
Transmission fluid or gear oil leak from the front transmission seal.
All 3 of these can look like they are coming from about the same place, where you have said.
All three of these require you separate the motor and transmission to fix them, and that means taking the transmission out of your truck.
Pretty expensive if you pay to have it done.
If you take the " tranny" out, most shops will replace both seals (one front, engine and one rear, tranny)
Depending on how much it is leaking and other things, lots of people let it leak.
If you are using a lot of fluid, perhaps it\'s time to think about repairs.
Be blessed
Jan 28, 2013 | Cars & Trucks
Oil leak front engine timing chan
1995 Tracker would have a timing BELT. Normal oil leak points (in order) on a Suzuki G16 engine are the distributor base (rear of motor), valve cover (top of motor), front main seal (behind lower timing belt cog) cam seal (behind the upper timing belt cog) and rear main seal. (behind the flywheel). I'd suspect the front main seal or cam seal. I use foot power to help find oil leaks.
Dec 24, 2012 | 1995 Geo Tracker
Oil leaking or burning
this can be very simple to solve,after you've driven the car for,say,20 miles or maybe even 15 miles,place a piece of plain brown cardboard under the motor on ground.under the motor.make sure the engines not running,just slide the cardboard under the motor on the ground.you can even put a big piece under the whole front of car,from side to side. your whole motor is in front,including the transmission. black fluid is oil leak,red fluid is transmission fluid. if your engines burning oil,then you'll be adding oil to your engine constantly. depending on how often you drive your vehicle. just remember black fluids oil leak,red fluids,transmission fluid leak. if your motors smoking black while running, that's oil burning with your gas. you may only have a simple issue,your check engine light on? autozone or advance auto parts store can read the codes for free!! thank you,for choosing fixya.com
Feb 20, 2011 | 1998 Plymouth Breeze
Bad oil leak using 1 qt. every 150 miles no excessive amount of oil seen in engine compartment for that amount of leakage. oil is around front of motor.
sounds like a front seal. it is 13 years old and they do go bad. take a search on youtube or buy a repair manual on eBay and decide if you want to take on the job. if not you will have to pay someone to replace it as it will not just go away. it is a toyota so should be good for a quarter million miles assuming all the owners have taken good care of it. if you are past that mileage you may want to consider a rebuilt engine swap instead of replacing one seal.
Jan 23, 2011 | 1998 Toyota Corolla
Leak in the front of the motor, kind of looks red
If it is on the passengers side front then it could be coolant.have the cooling system pressure tested.Could be a water pump,intake gasket,or radiator hose.Depending on what motor you have.Hope this helps.Good luck.
May 10, 2010 | 2004 Pontiac Grand Am
Kitchen Ranges Logo
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
