Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Tech rep mode bizhub - Konica Minolta bizhub 250 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,680 Answers
Utility/counter details stop00 stop01
Posted on Dec 28, 2015
4 Suggested Answers
SOURCE: Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
  • 44 Answers
SOURCE: konica minolta bizhub 750 photocopier how do i get
press utilility, meter count, details, then press, 1,2,3,4,5,6,7,8
Posted on Jun 28, 2010
  • 7 Answers
SOURCE: Bizhub 350 Error CD004
CD004 "failed to overwrite" error? This worked for me. I am not sure how complete the overwrite was but it blanked out all the addresses that used to show on the test sheet.
I tried the 35 hour(!) "overwrite" function but it kept getting CD004 error. This process allowed me to unlock printing function again and wipe the HD.
go to Service Mode (hit these buttons: utility/counters>details>stop>0>0>stop>0>1>Password:00000000>end
go to System Input, turn HD to NO, hit END, home screen will show "failed to overwrite data" again, turn main power switch off for 10 seconds and then turn it on again, home screen should show "all data overwritten"
Go to utility>admin management>Password:12345678>Format hard drive> Format is complete> turn main power off for ten seconds and then on again
Print function should be restored. Go into System Mode again and turn the hard drive back to YES/ON
Posted on Jan 14, 2011
HOW DO I BRING UP KEYBOARD TO RUN F8
f8 is function 8 in the tech rep mode which is the atdcadjustment. to get into service mode go to utility>meters>details and press STOP,0,0,STOP,0,1. Then got into FUNCTION to find F8.
If you are doing this because of an error code and/or maintenance you must first go into tech rep mode>counters>special parts counter> and reset drum life then power off machine, replace drum AND developer, restart and do the F8.
Jan 07, 2015 | Konica Minolta bizhub 250 All-In-One Laser...
I forgot my Bizhub 223 administrator password
The admin password is 12345678 yes you can change the password you will need to log into the tech rep mode once in tech rep mode you need to press the following buttons stop 0, then the C button
once this is done you then select admin password and change it
Aug 04, 2014 | Konica Minolta Bizhub 223 Copier
Bizhub c350
Before replacing the IU select Utility - Meter count - Check details- Stop 00 Stop 01,enter 00000000 END,select Tech.Rep.Mode - Counter - Special parts counter-PC life.Press the Clear key to clear the counter value.Select IC life and clear the counter value.Turn OFF the copier and remove IU unit.After installing the new IU unit select Tehc.Rep.Mode -Function-F8 and press START.After 2 minutes the developer is initialized to make a copies. fcf3fced-96eb-4483-840f-8de548aa8045.jpg 378b39ea-2f19-4cf6-887c-617430da4931.jpg
Jul 14, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bill is detected
I looked through the service manual for this and I see "tech rep mode" listed. I don't think you can access this from your digital screen, but look for it. Other than that it suggested opening the "front door" and closing it again with the power on to reset. Hope this helps. If you manage to access the Tech Rep mode, there is a button to press to reset the machine...
Nov 06, 2013 | Konica Minolta Bizhub C350 Digital Copier,...
Cant access tech rep mode
Hi TECH REP MODE IS NOT 12345678 0R 00000000 THESE ARE TO GET INTO ADMINISTRATOR PASSWORDS TO GET INTO ADMIN TO GET INTO TECH REP MODE YOU HAVE TO PRESS UTILITY KEY METER ON DISPLAY DETAILS THEN STOP 00 STOP 01 IN THIS ORDER ONE AFTER THE OTHER THIS WILL TAKE YOU INTO TECH REP MODE...
HOWEVER THIS MODE IS FOR TRAINED CERTIFIED TECHNICIANS ONLY AND IS NOT FOR USE BY HAVE A GO DIY PEOPLE ENTERING INTO THE TECH REP MODE MAY CAUSE DAMAGE BEYOND REPAIR TO NO CERTIFIED TECHNICANS YOU HAVE BEEN WARNED GET TRAINED FIRST
Dec 12, 2011 | Minolta bizhub 350 Black and White Copier
Konica Minolta bizhub reads "server disk full": how to unfill server disk? or how to fix?
CAUSE: Machine memory is corrupt and the max out time needs to be increased.
SOLUTION: Perform a Data Clear:
1. Enter the Tech Rep mode.
2. Press System 1.
3. Press Initialization.
4. Press Data Clear.
Also browse to the NIC, enter Admin mode and set the connection timeout for E-mail to 300 seconds.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
HI THERE , I GOT ONE PROBLEM IN BIZHUB250B ERROR C2557 .. I PUT OLD DRUM,DEVELOPERAND I RESERT F8 AND RESERT COUNTER STILL ERROR CODE IS THERE , AND ALSO PUT NEW PARTS DRUM DEVELOPER, ATDC STILL THE SAME...
1.press the utility button
2.meter count and details button
3.enter tech rep mode: stop,0,0,stop,01
4.select tech rep choice mode
5.select printer tab
6.select atdc sensor gain
7.set value to 165
back out to the ready screen then power off then on the machine have done this many times and just fixed one today with the same problem
Nov 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Has code C2557
usualy this means the drum was replaced without replacing the developer do the steps listed below and the machine will work until the developer can be replaced:
1 press the utility button
2 meter and details buttons
3 enter tech rep mode; stop,0,0stop,0,1
4 select tech rep choice mode
5 select printer tab
6 select atdc sensor gain
7 set value to 167
back all the way out to the ready screen then power the machine off then on. should work
Apr 27, 2009 | Konica Minolta Bizhub-200 Minolta Printer
Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
