Why is my JVC DR10 Resetting all the time
On plug in cooling fan runs for about 5 sec display shows "please wait". This lasts for about 5 mins then goes blank. The unit will not accept any inputs from the remote or the front panel buttons. After a while the display comes on with "Resetting" flashing on and off, this can last for up to 5 min and then goes off again with the unit not accepting any inputs. I am unable to switch the unit on.
bluegreenash
  • 661 Answers
SOURCE: Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Posted on Oct 15, 2007
SOURCE: Frigidaire GLTF2940ES
Is it draining completely?
Posted on Feb 07, 2008
tech48
  • 624 Answers
SOURCE: Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Posted on Jun 18, 2008
SOURCE: DVD Recorder frozen - please wait on display
Just wanted to supplement DC's solution with photos for those who would like to see the project before attempting. For the record this fix worked perfectly and my unit is back to perfect working order with all my recordings intact.
Start by removing the top cover of the unit.
Working from the back of the unit you'll see the hard drive on the left.
Remove the two screws indicated by the red circles in the picture above. Then slide the cover plate forward and remove.
Two cables are connected to the hard drive. Left side is power and the black ribbon is the data connector. Both come off pretty easily. After removing cables lift out hard drive. Here's what you get.
Better view of cables after removing the drive. Remove plastic drive liner.
Remove the four screws indicated by the red circles in the picture above. Note the one at the top. (I missed this one for a few moments while putting it back together.) Remove drive mount.
Viola! You now see the burned out capacitors. Also circled are the four screw holes you just removed screws from and a cable that must be disconnected. (see next pic)
Gently pry up on the black plastic part of the cable mounted on the power board. You can see in this picture how I've just started to get it off a bit. You may have to pull on the latch in the center of the mounting. I did but I don't know if it was necessary.
On the back of the unit remove one screw just above the power plug. Then rock and twist and hold your tongue just right to get the power supply board out.
You'll see the capacitor numbers labeled on the circuit board on the front and...
on the back. Use a soldering gun to melt the solder on these four spots rocking the capacitors out of the holes as you do so. Just don't get solder over to any adjacent circuits.
You end up with nicely marked pos/neg info on the board.
Get your new capacitors from Radio Shack or other electronics store.
The ones suggested by DC are more heavy duty so they are bigger. I chose to lay them on their side so as to not raise the height of the board components. There is plenty of room to do so making my decision to do so a no brainer.
I leave the leads on the capacitors long until the capacitors are positioned and soldered in good shape.
Then clip the extra lead down to the solder with a wire cutter.
Thats it. reverse the directions to re-assemble the unit.
Hope the pictures helped. They always seem to help me prepare for such an adventure.
Posted on Sep 01, 2008
SOURCE: air conditioner
I managed to find the people who supplied the unit, it was still under warranty, and they said it was the thermistors (temprature probes, they replaced both of them) It is now working perfectly!
Posted on Sep 24, 2008
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
The upstairs ac display is blinking cool on, but not cooling the house. The outside fan is running. please help. The downstairs display and unit working properly
Normally Honeywell will "blink" COOL ON when its in a timed delay, usually 3-5 mins. And then COOL ON will stay on without blinking. If you turn tstat off then wait about 5 mins, then turn to cool, watch for the blinking, then wait 5 more. If it doesn't turn on, check/change the batteries if it has them. Try turning the AUTO/ON to the on position to bring on the fan only. It won't cool doing this but it helps in homeowner troubleshooting.
Aug 05, 2015 | Honeywell Heating & Cooling
Intermittent Cooling
try them online next time might help.
Aug 06, 2012 | Fisher and Paykel Refrigerators
Need to know why a 97 mercury cougar won't start until cooling fan and fuel pump stop running
I would think it's a problem with (CCRM) constant control relay module . This module has relay's inside that control the fuel pump , cooling fans , A/C compressor clutch , PCM - engine computer power relay . And thier are electronics involved , solid state circuity . Google CCRM
found this helpful answer from mercury mechanic on JustAnswer com
May 07, 2017 | 1997 Mercury Cougar XR7
The lock is on and we do not know how to shut it off
Hello there:
There are 2 ways to unlock these
the first is to unplug the appliance for 30 seconds then plug it back in then wait 30 seconds and repeat do this a total of three times then on the last time plug it in and wait 5 min and then press the unlock as usual
Now on the newer models you need to unplug it for a minimum of 1 hour to allow the internal resetting feature to reset the appliance fully then simply plug it in and wait 5 min and you should hear it unlock automatically or jsut wit the five min and then unlock it as you would normally do ok
Hope this is all very helpful please keep me posted on how this is going
Best regards Michael
Apr 29, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Cant turn it off, it seems to be locked?
hELLO THERE
On some of these ovens they have a internal reset device that needs to be reset and this is done by unplugging the oven and waiting for one hour then plugging it back in and waiting for 5 min befor you attempt to unlock it.
Now on some of the newer model ovens all you have to do is unplug wait 15 sec and plug it back in for 5 sec then repeat this step 3 times ok so please try these and let me know how this goes
Apr 26, 2010 | KitchenAid Architect Series KEBC107KSS...
This is for Ginko: Last Tuesday I described a problem with my Gateway 3520 going to "black screen" 5 secs after turn on. You analyzed a cooling fan problem. I removed the cover etc. and found that the fan...
see if the connectors are broken or working
the wires/board integrations are intact or not
see if it works
if not post any other data adn i will solve it
Dec 14, 2008 | Computers & Internet
Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Ps3 light on but freezes
Hey ok wait a sec so nothing is displayed on the screen?
Does it power off or down?
Ok it sounds like a simple setting error..
Turn system off then on and let the red light show up.
Then push the power button down for 5 sec and/or wait until it beeps.. it will reset itself and turn back on.. still nothing? do it up to 10 times and let me know if this is not the issue thanks!!
Jun 27, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
