Question about Bissell 1950-3 Quicksteamer Plus Vacuum
Cleaning I cannot get the cleaner to release solution on carpet. have lost manual. is there a trick to this? I have tried squeezing trigger handle to dispense solution with no luck. have followed instructions (2 capfuls cleaner, fill with hot water to fill line) on filling tank.
  • 1,673 Answers
Re: Cleaning
Either you have a pinched or clogged water line, or the rod in the handle is pushing down like it should. The drw back is Bissell has deemed this unit and its parts obsolete. So any parts are hard to find.
Posted on Feb 13, 2008
0 characters
3 Points
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
No water getting to brushs
Hi! Sometimes it is necessary to prime the trigger under the handle to get the solution flowing. To prime the trigger, recline the handle and pump trigger about 60 times. Then, power the cleaner on and squeeze the trigger for about 60 seconds. The solution should start to dispense. If it is still not dispensing there may be an issue with the pump assembly on the cleaner. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate one nearest you. Service Center Locator
Hope this helps!
Jun 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Why is thecleaner not coming out of carpet cleaner
You have to continually hold the trigger to release the cleaning solution. If you don't hold the trigger closed then you are running the vacuum in carpet drying mode.
May 25, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
Been cleaning for 2 hours now with my Bissell Quicksteamer and on my next run i presses the water release trigger on the handle and water isnt being squirted on the carpet..why?
ran out of water? (if water) >
Is there some form of water filter?
Problem with the trigger?
Bad steam heating element or the power connection supplying the power to it?
Of could it just be tired and need a break? (grin)
Best Regards
Aug 16, 2011 | Vacuums
Have a D4 model rainbow vaccum cleaner and want 2 no how 2 shampoo with it please help me
put cleaning solution into the proper receptacle lower brushes making contact with the surface to be cleaned. turn the on off switch on. start at the edge of the carpet squeezing the trigger for cleaning solution release and pull backwards.release trigger. roll vacuum back to begining position and pull backwards without squeezing solution release trigger. push back to the top slightly overlapping the first pass and repeat procedure. after rug is been completely shampooed allow to dry. after rug is dry sweep with broom
Feb 26, 2011 | Vacuums
Water and solution do not dispense.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Carpet steamer continually sprays water/cleaner. Can't stop it!
This is a solution for the Bissell Pro Heat, although it may apply to other Bissell steam cleaners as well. This is for the problem of the cleaning solution continually spraying without stop.
I found a quick and simple solution to this problem.
This problem occurs because the valve that allows the solution to flow gets "sticky" and will not close. The valve is engaged by the trigger mechanism in the handle. Squeezing the trigger pushes downward on the valve's plunger, but the spring in the valve that is meant to push the plunger back up to the closed position is not capable of doing so.
Here's the solution:
This valve is white and resides about half way down the vertical handle portion of the cleaner. To get to it, unscrew the 2 black screws that hold the top part of the handle to the bottom part. These are the same screws that you used for assembling the cleaner when you first bought it. Pull the top portion of the handle up and it should slide out.
Now, looking down into the handle body of the remaining portion of the handle, you'll see the top of the white valve. If you push down on the top of the valve (like the trigger mechanism in the top part of the handle you just removed does) it may go down some, but it probably won't go back up by itself like it should.
I found that lubricating this plunger with dish soap was the trick. If you can't get enough access to the valve to do this, you can remove the seven phillips head screws in the lower portion of the handle and pry it apart. I did this. I even took the valve out and put soap around the plunger and into the valve itself. I worked it up and down until it had a quick and positive open/close action.
Reassemble and you should be good to go. You'll notice that the trigger now has a more positive feel to it. I hope this helps.
Dec 14, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Bissell 1950-3 Quicksteamer Plus Vacuum Logo
438 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
