Question about NewAir 84-Can Beverage Cooler
Reverse door on newair fridge - NewAir 84-Can Beverage Cooler
Door reverse
The buttons should just pop straight up. Sometimes they are a little tight. Be patient, maybe use a small sharp knife between the button and the fridge.
Dec 14, 2017 | Refrigerators
How do you reverse the door
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Mar 28, 2016 | Refrigerators
Reverse door.
Some cannot be reversed....
May 28, 2015 | Amana Refrigerators
How do you reverse the doors on norcold n641r fridge
remove freezer door first then fridge door change handles and reverse hinges
Mar 01, 2014 | Thetford NORCOLD Refrigerator Lower Door...
Need to locate a operations manual. Moved into a house that has unit but no instructions
Could this be what you're looking for: http://www.newair.com/manuals/newair-ac-14000h.pdf
Jan 14, 2013 | NewAir ACP-1400H Portable Air Conditioner
Reverse doors freezer hinge
What is the model number of your unit?
Nov 28, 2012 | Refrigerators
Reversed a door
you should be able to reverse your doors just take bolts out on hinges pop out plugs on oppasite side
Aug 28, 2009 | Frigidaire FRT21H8 Top Freezer...
We have a fridge/freezer, upright bought some 15 years ago. Works fine, but we wish to reverse the doors to right opening from left. Please advise how to do it.
if you can notice that the doors have plastic plugs to the other side of the hinge then it is design to be reversible.
but if there is no indication that you can transfer the hinge to the other side of the door, then it is not designed to be reversible and there is nothing you can do about it.
i'm not sure if the old fridge are designed to be reversible.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Refrigerators
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
NewAir 84-Can Beverage Cooler Logo
12 people viewed this question
Top NewAir Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a NewAir Refrigerator Expert? Answer questions, earn points and help others
