Question about Whirlpool Ovens
What can I do to fix my Wirlpool Gas Oven? Mo. # WFG361LVB
I have a Whirl Pool Gas Oven. When I attempt to use the oven the oven will start up go up to 190 degrees and then shut off. The Broiler works fine. There are no local service techs. What do I need to do to fix the stove?
  • Whirlpool Master
  • 5,323 Answers
I would check my oven gas safety valve first
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
Posted on Apr 09, 2015
  • 10 Answers
SOURCE: burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Posted on Nov 19, 2007
  • 21 Answers
SOURCE: Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Posted on Jan 13, 2009
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
  • 57 Answers
SOURCE: Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
Posted on Jun 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 26, 2010
Testimonial: "This advise seems right on. Thanks for your fast and detailed advise. Steve"
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
My whirl pool oven is heating even though it has not been turned on. Seems to be from the upeer element.
Sounds like the broil relay on the control board is welded shut. The board can be rebuilt at www.fixyourboard.com
Jun 26, 2010 | Ovens
My oven light does not work at all, how to replace
reach inside and unscrew the old bulb and screw in a new 1
Nov 09, 2009 | Ovens
2 year old elect range/oven by wirlpool will not
check your input voltage your probably losing a leg and only have 120volts instead of 240 volts that would cause a reduced heat symptom
Jul 16, 2009 | Ovens
Whirl Pool oven broil will not go off
only thing i can think he was talking about is the controller and it cost about $175.00 and here is the part number 8186024 / larry
Dec 02, 2008 | Whirlpool RBS245PDS Electric Single Oven
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Oct 08, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
Mar 16, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirl pool single oven AKP 510
there is a thermo fuse on unit most often on back or control panel
Aug 13, 2007 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
134 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
