Question about Konica Minolta Office Equipment & Supplies
Code m2 bizhub164 starting start call{m2} way i reset this code
    Habit-Forming:
  • 43 Answers
Menu,quick setting,<<quick setting <> and go to service choise ,maintenanc 0 press sit down go to clear data and clear maintenanc and supplies
Posted on Sep 08, 2015
How can I remove code m2 in Minolta 215 coppier
Hi fatma, this is most likely a maintenance counter error. You need to reset the maintenance counter. Do so by pressing: Select [Service Mode] [CLEAR DATA] [PM COUNTER]
This should enable the printer to start working again.
Hope this helps!
Oct 28, 2014 | Office Equipment & Supplies
How to reset m2 error
Have you replace the developer and the drum. First clear the counters for the drum and developer and then replace the drum and developer, then run the required F8. if not the machine will start showing bad copies showing codes. If you clear the counters and don't do anything then the copier will think the parts are new set voltages as required when in fact they are old and will cause problems. So recommend you do the right thing get a tech out to replace the drum and developer
May 19, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhub 215 showing maintenance call(m2) and service call
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply count then ok to clear. On/ Off the machine it will work as usual.
Apr 03, 2014 | Minolta Office Equipment & Supplies
What would be the genuine problem when konica minolta bizhub 215 shows maintainence call(m2)
Procedure
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Apr 03, 2014 | Minolta bizhub 180 Black and White Copier
Konica Minolta bizhub164 C3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Turn ON the power switch with the Back/Stop/Reset key held down.
Jan 14, 2014 | Konica Minolta bizhub 200 Printer
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
Need RC410-M2 (V1.0) Motherboards manual
need manual showing front panel conections for start reset ect
Dec 04, 2009 | EliteGroup RC410L/800-M2 (V1.0)...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Code m2
M2 is a maintenance code, it is usually tied to one of the machines consumable products, drum, developer, or fuser rollers. These items should be checked before attempting to reset the code.
Hope this helps.
Ed
May 11, 2009 | Konica Minolta DiALTA CF910 Copier
75 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
