Question about Konica Minolta bizhub C450P Laser Printer
Konica Minolta C6000 error code C6801 - Konica Minolta bizhub C450P Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
After the sub power switch
(SW2) turns ON, the
communication between
the overall control board
(OACB) and the operation
board /1 (OB1) is not
started within a specified
period of time.
Had these boards been replaced recently???? If not will require you to the check each connector remove one at a time and check each connector on the boards for a bend pin this will be time consuming worse case you have a Bad board (S) SERIOUS $$$$$$$$$$$$$$$$. Also mite want a tech to come out and check that firmware is not bad. Can only get firmware from secure Konica Minolta Web site.
Posted on Dec 28, 2015
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
SOURCE: IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Posted on Aug 23, 2009
  • 5 Answers
SOURCE: error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Posted on Feb 19, 2010
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
What is c2704 in konica minolta c6000
I think that is the code for the black charger unit. It might be the charger itself or a board problem. Make sure the black charger is seated correctly.
Nov 01, 2014 | Konica Minolta Bizhub Press C6000 Copier
How do i reset the error code c2704 in konica minolta press c6000/7000
Thread 2704
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
Best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Nov 01, 2014 | Konica Minolta bizhub Office Equipment &...
Por que impressora konica minolta bizhub c6000 apresenta error 2703
Check the Cyan Charge Corona housing. Remove it and reseat it. IF not that check the HV board. and or connection at the back of the drum and transfer middle assy.
Oct 16, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica minolta error code c-4502
Main body: Writing correction drive abnormality
Cause> The tilt correction home sensor /M (PS71) turns OFF while the tilt correction motor /M (M75) in the writing unit is ON.
Estimated abnormal parts> • Printer control board (PRCB) • Writing unit
Jul 18, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica bizhub press c6000 AA errors
What is the error code C-XXXX or SC-XXXX or Jxx-xx what was it doing when it happened?
Jun 05, 2014 | Konica Minolta Bizhub Press C6000 Copier
IC 601 controller is connected to my konica minolta bizhub C6000 printer but display is showing controller is not connected
check the cable between the print controller/firey and the copier, also is the print controller/firey set up for a c6000
Feb 07, 2014 | Konica Minolta Office Equipment & Supplies
Code d'erreur C3505
Fusing error have tech look at and reset
Jan 24, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica Minolta bizhub C450P Laser Printer Logo
300 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
