Question about Electrolux Dishwashers
Electrolux 2430 dishwasher pump doesn't stop
The pump doesn't switch of and no light are on. this has happened before and the service guy said the sensor was dirty. how can i clean it myself?
  • Official Brand Answer
  • 4,342 Answers
Good Morning Friend,
I understand the pump does not switch off of your Electrolux 2430 dishwasher, and you are wondering how to clean the sensor yourself. Typically this is not a do it yourself job. This appears to be a UK Electrolux dishwasher. I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best Regards-
WP
Posted on May 21, 2014
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
tzweeb
  • 318 Answers
SOURCE: dishwasher stops during cycle and full of dirty water
you are having a problem with your door latch.the unit may not be staying closed or the latch strike is not in position to engage the door switches.
check the metal bracket just where the door closes and try to bend it downward , closer to the door and see if this helps to keep it working.
Posted on Jan 20, 2010
  • 5603 Answers
SOURCE: Grinding noise in Electrolux edw550 dishwasher
One cause can be if the seal failed and allowed some watter to get into the motor bearings. Look to see if this might have occured. The other thing is if debris got into the pump impellers and cannot clear. This can tear up the impellers.
Posted on Feb 12, 2010
Daniel S
  • 4323 Answers
SOURCE: My Electrolux dishwasher "start/cancel" switch
Hi
The issue is with the control panel that should be replaced as it is bad. You can check this diagram and buy the parts from this link. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 08, 2011
SOURCE: Dishlex Global 450 flashes ''oF'' - Continues to drain
I also had the oF error message just today, tilted the dishwasher back 45degrees and message dissappeared and all sweet as now. Put old towel under legs to catch overflow Thanks to david
Posted on Apr 29, 2012
Ei24id30qs Electrolux dishwasher, drain pump won't shut off until it times out. tech manual refers to a level switch but schematic does not show it. Is it integral to the drain pump?
Not sure if this is same as my (older) dishwasher, but mine has a float switch ( a piece of styrofoam which triggers a microswitch) which sits in the bottom pan. As soon as any water accumulates here, the pump keeps running. I then get error code 30.
Nov 15, 2016 | Electrolux 24" Stainless Steel Built-In...
Hi i just bought Electrolux Dishwasher ESF2433W When i first time turn it on, the "Normal" button light keep on flashing with beeping sound. According to the trouble shooting manual, it actually refer to...
If you just bought Dishwasher ESF2433W I suggest you contact an authorized service center because the appliance is under warranty..
E4 : if overflow micro-switch is act and keep for longer than 2 seconds, the E4 would occur. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown.
Sometimes defects are generated by incorrect transportation appliances so that should be taken into consideration.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Ex500isc displays error 20
Have you tried making sure the water entering the machine is very hot by running the attached faucet Mr. Burns?
We had this happen when we turned our water heater down to it's minimum setting and forgot to run the kitchen faucet (supply was also plumbed to the dishwasher) until fully heated up, then switching on the dishwasher.
Mar 27, 2014 | Electrolux Dishwashers
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
Aeg electrolux dishwasher wont wash just keeps beeping
well there are several possibility's. What was the washer doing? Rinse or cleaning? If there is standing water in the tub, then the pump went out or is clogged.
Dec 04, 2012 | Dishwashers
After unit runs for a minute it stops ,open door and all lights are flashing.took bottom panel off and light forwash pump on,green but not flashing, took screen off didn't see anything.
It is possible the wash pump is faulty and is preventing the water from circulating leading to error condition.
Refer this document for service details and connections.
May 20, 2011 | Electrolux 24 in. EDW5500DSS Stainless...
Magicolor 2430 DL Fatal Error Code: 12H
I advice you power off the magicolor 2430 DL and power on after few minutes, while the magicolor 2430 DL is loading or booting, pull out the plug from the AC outlet and wait for minutes before plugging it back and power on, if the problem still per, press the stop button for about 5 seconds and release, see what happens, if it fix the problem.
Let me no what happens.
Take care.
Jul 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Dishwashers Logo
83 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Colin Stickland
Colin Stickland
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
