Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Kyocera km 3035 paper jam sensor location
Location of paper jam sensor
SOURCE: KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Posted on Jun 19, 2008
SOURCE: Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Posted on Aug 15, 2008
leroyal
  • 2120 Answers
SOURCE: not getting faxes
Press the fax button....look in the tabs to set machine to auto-receive.
press ON HOOK and listen for the dial tone.
Posted on Jan 02, 2009
leroyal
  • 2120 Answers
SOURCE: What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Posted on Feb 13, 2009
leroyal
  • 2120 Answers
SOURCE: print out landscape
Make cassette number 1 8 X 11. Load paper portrait in tray 1
Posted on Mar 08, 2009
Remove paper jam 21
http://usa.kyoceradocumentsolutions.com/americas/jsp/upload/resource/11858/0/3035-4035-5035ENOGR6.pdf
Jun 05, 2015 | Kyocera Mita KM-3035 All-In-One Laser...
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
My kyosera mita 5035 it says tray its out of oder
This usually means that you have some torn paper jammed behind the cassette.remove the cassette and the torn paper.
Oct 05, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera km 5035 error c2500
Paper feed motor problem.
Ensure that all cassettes are correctly loaded with paper.
Ensure that by removing the paper cassettes no paper is jammed behind them/in the copier.
press 1087 1087 on the key pad,then 906 then start,then execute then start.
Press 001 to exit.
Aug 14, 2013 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
J21 code on a Kyocera KM 3035
Multiple sheets in paper feed section (jam code 21) Feed switch 3 (FSW3) of the copier and the desk feed switch (DFSW) do not turn off within the time required to convey the length of the used paper size plus 635 ms of turning on.
Elektrotanya for electronics experts
Service manual attached.
May 15, 2012 | Kyocera Office Equipment & Supplies
Kyocera Km-3035 Locked in cardstock
press default setting/counter button
press bypass setting
press paper type
Apr 03, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Print out landscape
Mar 08, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Hopes this helps.
Henry
Jul 20, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
