Question about Nortel T7316E 2-Line Corded Phone
How can i set the company greeting on a t3716
Our company uses the Panasonic KX-T7730 phone system. When I change the answering message, it is immediately followed by an outdated message. Changing the message works, but the old message still fo
When we set up a Panasonic voice mail system, you have a menu that plays. Usually, there is a Company Greeting, then a Custom Greeting. They are changed from mailbox 998 option 5 then 1 or 3 depending on which greeting you want to change.
Of course, you may not have a TVA or TVx voice mail system, but I'm guessing that's what you have. In all cases, the Company greeting plays in front of the Custom greeting. By default in a TVA it's probably both greetings 1. You can log into the system and play them without changing them to verify what's where.
Carl
Feb 10, 2012 | Panasonic KX-T7730 Corded Phone
How do you set up voicemail on the Panasonic KX-T7636 system?
1. Raise the handset on any telephone in the Panasonic Telephone system.
2. Press the "INTERCOM" button and dial 165.
3. When answered by the Auto Attendant, dial # XXXXX * 9 9 8.
(Pound Six Star Nine Nine Eight)
4. Enter the Administrator Password. Followed by a #. (Pound) If required.
5. Dial 5 to "Modify Message"
6. Dial 1 to "To Change The Company Greeting"
7. Enter the Company Greeting Number from 1 to 32.
If you are not sure of which Company Greeting Number to change, then start with 1.
The Panasonic Voice Mail system will actually play the greeting to you.
Then you can determine if it is the correct one you want to change.
If it isn't, you can dial 2 and move on to next greeting and so on.
If you select a greeting number where there is no greeting recorded,
the Panasonic Voice Mail system will prompt you to record one at that time.
You may dial *1 (STAR ONE) to skip recording and return to Step 7.
8. When you have found the Company Greeting you want to re-record
follow the system prompts to record and save your new greeting.
Note:
You can change the Company Greetings remotely from anywhere.
1. Call the main number of your business.
2. When answered go to Step 3 and follow the same procedures.
3. When completed....Hang up....
Aug 09, 2011 | Panasonic KX-T7636-B Corded Phone
My phone is a Nortel Networks phone T7316e I want to change my personal greeting but when i press "pers" it asks me for a greeting number. I do not know what the number is. My extension is 21...
Recording Company Greeting 1 Press FEATURE 9 8 3
The display shows
Log: QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK
The display shows
Admin MBOX AA OTHR
4 Press AA
The display shows
Auto Atdt Admin GRTG TABLE LINES
5 Press GRTG
The display shows
Greeting Admin GRTG AA
6 Press GRTG
The display shows
Greeting: RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK
The display shows
Greeting RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting.
Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording.
The display shows Accept Greeting:
RETRY PLAY OK
NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play
1 From Step 12 press *
2 Press Table
Auto Atdt Admin GRTG TABLE LINES3 At Grtg table: enter 1
4 Grtg table: Retry OK
5 Press OK
6 Press OK again @ AA menu prompt
7 At Morning: 1 press CHNG to whichever new greeting you recorded
CHNG Morning: 1 PLAY NEXT
8 Continue by pushing next through all times
9 Afternoon:2 CHNG PLAY NEXT
10 You should note which times had which greetings to change back after holiday
11 After you change all the times Morning Afternoon Evening Non-business press Release
This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
Feb 24, 2011 | NorStar T7316E Corded Phone
How do I set a temporary holiday company greeting?
Most of my customers called their dealer :-)
You need access to the voice mail system and a Holiday custom message or company greeting. After that, it's fairly easy to tell the system when the Holiday message should be played.
Carl
Dec 21, 2010 | Panasonic KX-T7633 Corded Phone
Callers are not prompted to general mailbox
Under greeting table 1 set your greeting attendant assignment as 100,that should send the caller to mbox 100 if they press 0 or make no selection at all
Sep 29, 2009 | NorStar M7310 Corded Phone
T3716 Norstar Phone
If you know how to access admin programming. Yes, all the phones are probably set to "appear only"you need to go into line appearance for all the extensions and make them "appear and ring" If you find it, you can copy that programming from the phone that is already ringing.
Jun 25, 2009 | Nortel T7316E 2-Line Corded Phone
Automated Attendent
Norstar Voicemail for 6.0 or less
Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG:", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Record the Company DAY & NIGHTGreetings:
1. Press AA
2. Press GRTG
3. Press GRTG
4. <Display> Greeting:
5. Enter 1 for DAY Greeting --- Enter 2 for NIGHT greeting
6. Press OK
7. Press REC to record.
Feb 25, 2009 | NorStar M7310 Phone
I am trying to change our company voicemail and the manual (with the company's contact info is, who we bought the phone from) has walked away. Is there a standard code for setting the main VM greeting?...
What Toshiba Voicemail system do you have? Is it a Toshiba or third party voicemail? Depending who setup you voicemail and what version you have. Mailbox 990 is the Intro greeting "thank you for calling xyz company". Mailbox 991 is the main greeting "press 1 for sales press 2 for tech support etc. If you have a toshiba Voicemail. Need to login to 990 and 991 (need to know passwords) Newer versions you can setup just 991 mailbox for both.
Nov 26, 2008 | Toshiba DKT 3010 Corded Phone
Company Greeting
I will assume you have a Norstar Voice Mail System, to record a Company Greeting, Press Feature 9 8 3, display shows " log ", enter password ( usually 1020000 ), press OK, display shows Admin with choices MBOX AA OTHR, press AA, display shows GRTG TABLE LINES, press GRTG, enter greeting number to be recorded ( 1 to 20 ), press OK, display shows greeting <X> with choices RETRY PLAY REC, press REC, at the sound of the tone record your greeting, DO NOT HANG UP, press OK,to end your recording,display shows Accept Greeting?, you can play or re-record by pressing PLAY or RETRY, press OK to accept greeting and RLS to get out of programming. Probably the greeting you want to re-record is greeting 1. Good Luck
Jul 31, 2008 | NorStar T7208 Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
15 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
