Question about Revel CCM104 220-volt Wet and Dry Coffee Spice Grinder, White"
How to remove the top cap - Revel CCM104 220-volt Wet and Dry Coffee Spice Grinder, White"
After I replace the tensioner elbow and refill coolant, do I need to get air out of the lines?
Yes you do have to burp the system. With radiator cap off (as opposed to the expansion tank reservoir which should also be off) the engine cold and the system almost full, squeeze the top and bottom radiator hoses sharply. Top up fully and replace the two caps. Bring the engine and water coolant to full temperature until the cooling fan kicks in. Wearing gloves, squeeze those hoses again with the engine running. You should feel the water surging. Turn off the engine and leave to cool. Remove the radiator cap and fill the system to the top. Replace the radiator cap. Remove the cap to the reservoir bottle and top that up to the MAX line. Job done and all the air pockets removed.
Jan 17, 2016 | 1996 Oldsmobile 88
Tip
How to Replace a Distributor Cap in Toyota?
Its a plastic cap and and on its top the sparks wires get connected.A small plastic rotor spins inside the distributor cap, firing each spark plug as it rotates. If the distributor gets faulty there the engine may not perform well. in most cases it has been noticed that only replacing the cap does not helps but with cap the rotors also need to be replaced. The procedure is as follows:--- 1) First of all disconnect the negative battery terminal. 2) Then remove the spark-plug wires . Note:-- Before removing the spark plug wires please note down how and where the wires are connected,then only remove the connections. 3) Then on the distributor there will be a cap.remove that cap.the cap is connected by two pins.you will have to press the pins from each side to loosen the distributor cap.Then lift the distributor cap from the top. 4)Then remove the rotor From distributor The rotor is fitted with two screws.Remove the screws and loosen the rotor. 5) Then lift the rotor out from its shaft. 6) To install new rotor and cap.reverse the procedure. This will help.Thanks.
on Mar 25, 2010 | Toyota Corolla Cars & Trucks
I want to split my fz16s front fork
Before you remove the fork loosen the top triple clamp on the fork you want to remove. Now loosen the top cap of the fork. Loosen the bottom triple clamp and slide the fork out of the bike. Remove the top cap of the fork.There is spring pressure pushing against the cap, but if the fork is not being compressed it not difficult to take off or to put back on. When it is removed pour the oil in to a container and reinstall the cap. In stall the cap all the way but you don't have to tighten it.
Slide the dust cap up and off of the fork without scratching any of the chrome. Now remove the "C" clip or spring that was under the dust seal and place with the dust seal.Flip the fork upside down to access the allen head bolt in the bottom of the fork. Using an impact driver break this loose. Once loose remove the top cap and spring from inside. Now remove the the bottom bolt. Holding both tubes of the fork compress and snap apart quickly. This might take a few times but the should come apart rather easily.
Oct 23, 2014 | Motorcycles
Where is the thermostat housing
Hi, Follow the top rad hose to the top of the engine, You will need a set of wrenches to remove the metal cap. Before removing cap you will have to drain cooling liquid half of radiator. Also do not remove when hot.(burns). under that elbow cap there is the thermostat. Replace if not working properly. Good luck.
Jan 06, 2012 | 1999 Oldsmobile Aurora
How do you remove Jacuzzi Waterfall handles to get to the valve. There are no visible screws??
On the top of each handle you will need a very small flat head screwdriver or something similar to "pop" the top cap off. Under that cap there is a phillips head screw so you can remove the handle.
Jan 10, 2011 | Jacuzzi Water Rainbow Tub Faucet ...
Where is the fill cap
Most common question is Radiator fill cap hope this is what your looking for???
On the front of the frame is the radiator. You'll see a frame around the outside of it. Remove the Four screws that hold the frame on and remove the frame. On top of the radiator is a cap looks like a regular radiator cap!!
WITH THE ENGINE COLD!!! Remove the cap and top off with 50/50 Distilled water and GREEN Anti freeze. (Ethyline Glycol)
Replace cap and resucure the frame with the four screws being careful not to damage the radiator or bend the frame. Check bike for anti-freeze leaks if none GO FOR A RIDE ;-]
Nov 17, 2010 | 2005 Suzuki Boulevard S50
How do i remove the agitator on my whirlpool ultimate care II top loader washer
first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Bottom agitating, but top freely spins
You need to get an agitator repair kit. Remove the cap on the agitator. Some have a second inside plastic cover/cap. You will need a long extension and rachet and 1/2" socket to remove the hold down bolt. Remove and replace the parts with the kit parts. Replace the cover. 10 minute repair... online kit is about $13.00.
Aug 03, 2009 | Kenmore 24032\24036 Top Load Washer
How to replace front oil seals, After removing the rubber caps on the top I suspected to see some bolts, but nothing....
First, drain the oil. There is a nut ont he side of the for to do this.
Now you have to remove the wheel and fender. remove the top cap to the fork. Inside the bottom of the fork is a allen head bolt. Remove it and the lower fork will slide off. You put the oil in at the top cap. Use the Harley fork oil.
Good luck and happy riding
Jun 24, 2009 | 1989 Suzuki GSX 400 XS Impulse
Can't remove end caps from Whirlpool Model GST9679PG1 top loader
take the two screws out.one on each side.then stand in front of machine and pull caps forward and up and your face of the machine will be up.
Mar 10, 2009 | Kenmore 24032\24036 Top Load Washer
Revel CCM104 220-volt Wet and Dry Coffee Spice Grinder, White" Logo
126 people viewed this question
Top Revel Home Experts
john h
Tom Chichester
Are you a Revel Home Expert? Answer questions, earn points and help others
