Question about Xerox Phaser 3100MFP/S Laser Printer
WHY DOES MY Xerox WorkCentre C20HAVE ERROR function impossible?
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
SOURCE: LSU Error
Hi Dear
I am facing LSU Error on my Xerox workstation PE 220
I am not able to do anything, please let me wat to do
i have lot of work penindg
urs
mujahid
Posted on Oct 13, 2008
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
  • 2072 Answers
SOURCE: What is error 010-333?
That is a fuser over heat code. You will most likely have to replace the fuser module. Or have service do that for you.
Posted on Jan 05, 2009
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
Xerox Phaser 3100MFP/S Laser Printer Logo
12 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
