Question about Sony VAIO VGN-N130G/W Notebook
Cd drive dosent work
I can hear it running and the light flashes on it but when i choose it from my computer it says insert disc.
  • 448 Answers
Please follow the instructions through the link to troubleshoot the CD/DVD drive.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C425906
If the issue persist after performing all the steps successfully then service may be required.
Posted on Jun 24, 2009
How to install anti virus
Insert the USB flash drive into one of the USB ports on your computer.
Momentarily a small prompt will appear saying the computer has detected a new removable device.
Insert the antivirus software installation CD into the disc drive of the computer to launch the installation wizard.
If you downloaded the program, double-click the downloaded file to launch the installation wizard.
Read through and accept the license agreement, then click "Browse" when shown the installation location.
A search window will appear on the screen. Choose the USB flash drive and click "OK."
Click "Next" for the installation name and select "Install." The antivirus program now will install onto the USB flash drive
hope this helps
Oct 10, 2012 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Will not recognize cd when inserted
Try This:
1.click on start->all programs->run and type in run box devmgmt.msc
You wil find a device manager box now you need to click on the symbol called "scan for hardware changes". Now once the changes is complated then restart the computer and see if you can view the cd's. But before doing so check that whether the cd drive icon is showing in the My Computer or not.
2.If the above solution dosent work out than try cleaning the lens from the lens cleaner disc. You can purchase it from any local computer shop.
3.If the above two dosent work out then probably its a chance that you need to change the cd player.
Sep 25, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
I would like to use my usb flash drive to install and troubleshoot my windows xp operating system. My dvd cdrw drive is not working. I have an error stating that the explorasy.sys file is not there when I...
We are going to do this the easy way....you need a computer of course and one that has a working cd/dvd player, a flash drive and a windows installation disc. A recovery disc will not work...you need a windows installation disc.
Go to the control panel > folder options > click on the "View" tab, scroll down and UN-check the box the says "hide protected operating system files", now click the bubble above that says "Show hidden files and folders.
Now get out of the control panel and insert the windows disc in the drive.
Go ahead and insert the flash drive into a usb port and let windows recognize the device and load it. It will give the device a drive letter.
After the disc loads, it may appear on your desktop and say to install Windows....just exit the program but don't eject the disc. Open "My Computer" and look for your cd/dvd drive and right click on it. Choose "open" from the choices and a list of files and folders will appear. Select all the files except for a file that says "desktop
Copy all the files and paste them into the flash drive that you can find in "My Computer" The files from the disc will now be written to the flash drive. Once the copy is completed, the flash drive can now be used to boot the computer.
Insert the usb drive into the laptop that needs fixing and power it up. After the flash screen appears, tap the F12 key to bring up the multi-boot options. Choose USB drive and hit enter. The laptop will boot off the usb drive and initiate the Windows files.
Jun 30, 2010 | Toshiba Satellite 2415-S205 Notebook
My Dell Latitude D620 Screen is Black and the keyboard dosent work when I turn on the computer. The only LED light that shows is the power light, the wifi or the little cylinder light dosent work. I can...
remove all attached devices like printers or flash drives. remove battery and power on using ac adapter only. if it still wont work, try another good ac adapter. make sure ac adapter light is on. if it still shows the power light on and nothing else, replace motherboard.
May 15, 2010 | Dell Latitude D620 Notebook
I have an HP Pavillion Slimline and the cd reader is not working any ideas?
When you say "not working" , can you clarify that a bit?
  • Is the drive opening?
  • Is the drives light flashing when you insert a disc?
  • Do you hear the disc spinning when you insert the disc?
  • Does the cd-drive show in "My Computer"?
There is an issue that I have ran into multiple times in the past few weeks that causes this issue. It is related to a Microsoft Update. To remedy the problem, goto this page and select the "Fix It" icon.
Oct 23, 2009 | HP Pavilion DV6700T Notebook
My disk drive is stuck and won't open
Try first a soft eject: Go to my computer, Point the CD-ROM drive, right click mouse button, and choose eject. If that dose not work, examine the face of the drive and look for a small pin hole. Insert a blunt paper clip in the pin hole and press gently. The drive should open.
Hope it helps.
Aug 29, 2009 | Sony VAIO PCV-V200G PC Desktop
Nothing happens when disc Inserted
If there are no activity lights, or a rhythmic flashing on the drive, then you may simply need a new drive. Small computer stores are usually the best place to go to get a replacement at low costs.
If you are just popping the disc in and waiting for something to happen, then your computer may not be automatically running the programs from the disc. In which case you will need to manually access the drive and run the correct program.
Good Luck!
Aug 06, 2009 | IBM (92P6581) for ThinkPad T40 (92P6581)...
Dvd/cd drive not working
my dvd cd1.gif drive in my laptop1.gif isnt working at all i can hear it start when i insert a movie or disc but then it stops and when i check for the driver in my
Feb 25, 2008 | Computers & Internet
G-drive media problem
install the drivers for the drive, right click my computer choose manage and then disc manage choose the g drive, right click on it and change the drive letter to w and it will work.
Feb 03, 2008 | G-Technology G-DRIVE (90801201) 250 GB...
Toshiba Satellite pro hl-dt-st dvdram gma-4082n
goto program defaults/media player/disc insertion= and choose the options you require. Or goto computer-cd/dvd drive and choose the program you wish to run the disc
Dec 10, 2007 | Toshiba Satellite A135 Notebook
Sony VAIO VGN-N130G/W Notebook Logo
98 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
