Question about Garmin Approach S1 Golf GPS Watch
Why want turn off because i can't charge it - Garmin Approach S1 Golf GPS Watch
It died and won't charge or turn on
could be the battery .. try taking the back off,take battery out and leave the battery out for 10 minuets ..then put it back in . this could help restart the charging cycle . if not then you'll need a new battery
Apr 24, 2015 | Garmin Approach S3 Touchscreen Golf Watch
I have Relic VX3J 3 Eye - stopped working after 2 years.
If turning the adjustment bead does not result in a clicking then it is likely quartz. I am presuming it did not require winding. So if it clicks and comes back to life it is automatic (just wear it to charge it) if not then it is likely quartz. Most automatic watches can also be manually wound to charge. This is better for the movement when it is fully unwound, 10 full turns to be on the cautious side from flat. It is unlikely you can overwind good quality modern watches as they have a clutch to prevent over winding. cheaper watches may or may not have this feature.
Mar 22, 2014 | Relic Watches
When I plug in my s1 the watch just turns on instead of going to the charging screen. How do I get the charging screen?
I have had the same problem, but got round it by first powering off the watch, then waiting a minute or so. Then I attach the clip, having made sure I have the pins exactly aligned before I let them touch the contacts. Even so, a slight wriggle might be necessary to get them properly seated. I get it to work one time in three this way - what a daft bit of design!
Jul 30, 2013 | Garmin Approach S1 Golf GPS Watch
Unable to turn on my plantronics 210 explorer bluetooth .therefore no light is showing in it. charger is fully charged
Sep 06, 2012 | Plantronics Explorer 210 Wireless...
MTG 900 SAYING "CHARGE" AND I'VE BEEN PUTTING
I am assuming you are reading the battery charge correctly. If so you need a new rechargable battery. Special battery so it is a little expensive. Make sure the person knows it is a "rechargable battery" you want. A regular battery will not work properly or recharge.
Nov 02, 2011 | Casio Atomic-Solar MTG900 Watch
My Fossil FS4283 had been working fine since the time I bought it in 1997. It stopped working suddenly a couple of days ago and no matter what I do doesn't start back. It doesn't have a battery and charges...
mcdevito75 here, Sounds like the chargeing system has gone bad in your Fossil watch, Best Bet look for a small watch repair shop in your area, have them take a look at thr watch.
Jul 02, 2010 | Watches
My watch is not moving . I want to know do I need to change the battery or it is self wind? ref. 384858.Thanks
Its easy to tell if its battery operated or self wind. Turn the crown (where you set the time) forward. Self wind watches will click as you turn the crown. If its battery operated then you will hear no clicks. Some watches have a screw down crown so if the crown wont turn forward then try turning back. Some watches have a capacitor that needs to be charged! Seiko Kinetics are charged by movement like an older automatic. Citizens are charged by light!
Jan 09, 2010 | Piaget Watches
Hello. I let a Citizen Black Eagle Skyhawk run completely. Even after charging it for 24 hours, the watch will not run. What is my course of action? Send it in?
After charging the Skyhawk/Black Eagle watch, you need to reset it.
Here's how to do it:
Turn the crown (knob) until it's in chronograph mode (CHR), then pull it out to TWO clicks. Push both buttons at the same time and the display should turn on. The push the crown back in to complete the reset.
If that does not work and you are 100% positive it should've charged...take it in for service. It could be a bad battery (rare).
Aug 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Garmin Approach S1 Golf GPS Watch Logo
43 people viewed this question
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
