Question about Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
Registration & warrenty for compact DCR038W - Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
Where can I download Danny service manuals
Support - Danby
www.danby.com/en-us/support/
DanbyProduct Registration Product Support & Manuals Find Parts .... Product Manuals. Select Product Category. All. Microwaves. Washing Machines ... Service Depots ..
Oct 29, 2015 | Danby DFF261WDB 9.2 Cu. Ft. Apartment Size...
Can a compact refridgerator be recharged
Yes, but you have to understand that if it needs recharged, it has a leak and must be found, repaired, evacuated then properly recharged. Most compact reefers only hold a few ounces of refrigerant, so it does not take much of a leak to affect its ability to cool....Your issue could be something other than refrigerant if its just not cooling.
Jul 14, 2014 | GE SFR03BAZBB 3.2 Cu. Ft. Compact...
My kenmore model 19502 freezer is not freezing
Have the same freezer bought the warrenty glad I did services tech said that he knew the porblem before he came to fix it compressor locked up at 7.9 amps he said this is an issues with 99.9 percent of this model. Light was on flashing but food would not freeze. Sears will replace for me they are giving me a diffrent model number. I had no power surge or nothing of that manner. Faulty appliance. A recall has'nt been issued... but it should
Oct 13, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
I HAVE AN EXTENDED WARRENTY ON MY FREEZER,IT STOPPED WORKING AND NO ONE ANSWERES AT FRIGIDAIRE ON SUNDAYS WHAT DO I DO I NEED AN AUTHERAZATION NUMBER TO CALL FOR REPAIRE
make sure the outlet has power. maybe plug a lamp or something into the outlet and see if it works. you may have tripped a breaker
i know know anything about contacting refrigidaire. good luck
Sep 09, 2012 | Freezers
I would like to register my new freezer
It can be done online at
https://www.danby.com/registration.php?ln=CE& (copy and paste)
If you have purchased an extended warranty you will need to go to this page to activate the extended warranty.
https://www.danby.com/warranty.php?ln=CE&tip=EXT
Hope this helps
Dec 04, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
HOW TO FIND REGISTRATION AND WARRANTY IN CANADA
You can register and warranty the Danby at the link below for Canada.
Good Luck and please rate 4 thumbs up for the free answer
Jul 14, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
We have a Kenmore freezer chest...lights come on but doesnt freeze model#253.9135381 serial #s409256481
first,have you defrosted the frzr recently?they must be defrosted manually. take the 2 screws holding the side panel on and see if you hear the compressor humming/running. if you do. then the problem is in the sealed syetem. they should to come w/a 5yr. parts & labor warrenty but it looks like your frzr was build in the 1990's...
tip: if you think it's your cold control.you could unplug unit and use a wire,jump out the cold control.
Jul 16, 2009 | Freezers
Registration & Warranty?
I cannot find sitefor registration & warranty for my new microwave that i purchases. Iris
Jul 30, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
ICE BUT NO CUBES
look inside ice bin to see if auger wheel is broke,sometimes the plastic wheel cut and break,hope this helps-mike
May 25, 2008 | Avanti Freezer Compact Ice Maker - 12 lbs....
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
59 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
charles
Are you a Danby Freezer Expert? Answer questions, earn points and help others
