Question about Frigidaire Heating & Cooling
I have a Frigidaire window ac, model # FRA186MT2. 18,000 BTU. No power on control panel, push on power button, no start. Unit has power to push on, off pc board. Help Please.
SOURCE: air conditioner
NO GAS
Posted on May 13, 2007
22yooper
  • 828 Answers
SOURCE: ac unit not powering / starting up
Did you try to plug a lamp into the same outlet as you have the A/C plugged into? It could be that you have no power at the outlet or the circuit breaker could be off or tripped. Something should run like the fan only position.
Posted on May 24, 2008
hemantraj
  • 638 Answers
SOURCE: Frigidaire AC Window, Model # FAC107P1A2
you have clearly mentioned in your question itself that electrical cord does have power going into the unit.i feel it may be the problem with your power cord wire . try replacing the cord first and check whether the power reaches the unit.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 29, 2008
SOURCE: Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Posted on Oct 20, 2008
  • 13 Answers
SOURCE: cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Posted on May 15, 2009
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Ac won't turn on after cleaning and E1 appears on control panel
E1, The e1 error code could mean multiple things. The most common fault with the unit is a stuck button on the access panel. Gently push each button in and out to ensure none of them are stuck. The panel may have malfunction due to moister. See that the unit is installed properly, and then leave it off for a few hours so the moister can dry up. if these two things dose not work then the temperature sensor could be bad. Heir 1-877-337-3639
Oct 01, 2014 | Haier 5200 BTU Window Air Conditioner...
Frigidaire airconditioner compressor keeps running after turning the unit off
Thanks for the post, friend!
I understand that the compressor continues to run after your Frigidaire air conditioner has turned off. From that information it sounds like there could be a possible issue within your control panel or relay. I would recommend a reset on the appliance, to perform a reset unplug the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in. If you continue to have an issue with your compressor I would seek assistance from a professional. Hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire 18,500 BTU Window-Mounted...
Ac unit keeps tripping the reset button
Good Afternoon Friend,
I understand your Frigidaire air conditioner, model# LRA074AT7, which keeps tripping the reset button. I see that it will start up and then trips the reset button after a minute or two. First, be sure the electrical service is adequate for the model you have chosen. This information can be found on the serial plate, which is located on the side of the cabinet and behind the grille. Secondly, be sure the air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Lastly, your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire 6500-BTU Window Room Air...
Not starting
Hello Pete T - From what you have described the air conditioner possibly have a defective power/control board or faulty plug. I would suggest contacting a professional to accurately diagnose and repair the unit.
Oct 02, 2012 | Frigidaire 15,100 BTU Heavy Duty Window...
AC unit LWHD 1800R won't turn on & test/reset does not respond.
Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
Jul 05, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
Does anyone know the power consumption in watts for the frigidaire model FAA067P7A2 6,000 BTU window unit?
yeah find the data plate on the ac muliply the RLA or amps by the voltage of the unit example 15 amps times 120volts= 1800 watts. hope this helps
Jun 07, 2009 | Heating & Cooling
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Heating & Cooling Logo
    Top Frigidaire Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
