Question about Tomtom GO 930 GPS Receiver
Blaupunkt RC09H infra-red remote control - Tomtom GO 930 GPS Receiver
Got a bauhn 55" Full HD TV but the remote is really slow you press a button and it takes like 5 minuets for it to change channel over or what ever why is this It's really annoying me now
If the intensity of infra-red light signal that emits by the remote control is weak; this type of fault can occur. Check the remote control for its infra-red emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
Nov 28, 2015 | Televison & Video
My remote for tv wont work ,bought new one still wont work ,
It sounds that the infra-red sensor inside the TV is faulty. Contact any service technician. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV
Jan 02, 2015 | Televison & Video
My digi door iii remote not working
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Oct 21, 2014 | Televison & Video
If I have a genie pro and am trying to program a universal remote - how many times do I need to click the remote to pair it with my garage door opener?
Is the garage remote infra red or radio? Does the universal remote support both modes of operation?
If it's infra red then simply follow the programming instructions for the universal as normal. If RF then you may need another type of universal remote control that supports RF modes
Oct 14, 2014 | Chamberlain Clicker Universal Remote...
I have a orion sled 46 in and the remote will turn it off but will not turn i on
Check the remote control for its infra-red emission. Although it works for switch OFF, if the intensity of infra-red rays are weak, it should switch it back ON. Check the remote control with fresh batteries. If it behaves like this even with fresh batteries, the infra-red emitter LED at the front of the remote control should be faulty, and need replacement. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Details about how to check a remote control is given.
Jan 01, 2014 | Orion1934 19" TV
Remote control not working brand new sony rm-lj301 remote
Check the remote control for its infra-red emission. Even new pieces might have the fault. You can check its infra-red emission, by a mobile phone having camera option. If you wish to get more details about how to check a remote control, check this link.http://electronicshelponline.blogspot.com/ If the remote control emits infra-red emission, and still TV do not respond to it, the fault will be due to a damaged infrared sensor inside TV. This part can be located just behind the infrared window at the front panel of the TV set. You have to open the TV, to access it and to replace with a new one. The part will look somewhat like these.
Jun 11, 2013 | Televison & Video
Remote does not respond to any function, tv is on and cannot change chanel or anything, frozen
you need to check the battery contact with the battery terminal make sure that the terminal is clean.
check open the cover of your remote and check the solder of the battery terminal from the pcb board use a soldering iron resolder it.
using your cellphone camera test the infra red emmision of your remote control aim the camera to the infra red of your remote.you must see at the screen of the camera that the infra red is lit when any button is pressed..if not the infra red is busted.
using your cellphone camera again to test the infra red emmision of your TV. Aim the camera to the infra red of your TV.you must see at the screen of the camera that the infra red is illuminating.if not the infra red sensor of the TV is busted.
Jun 21, 2011 | Universal Remote Control MX-3000 LCD...
Not responding after changing old battery
Sep 10, 2010 | Samsung TV Remote Control
Playstation 3 code for 1056B01 remote control
does the remote operate over bluethooth or infra red
im sure that the ps3 does not have infra red and the offical ps3 remote works over bluethooth like the controlers
Dec 17, 2009 | Sony Playstation 3 (PS3) Console
TV does not respond to remote commands. Remote has been verified to work as I am able to control my other LG TV. Tried a universal remote and still no response.
Then it is likely that the infra red receiver in the TV set is faulty - or possibly the 5 volt supply to the receiver.
The signals from the infra red receiver usually enter the system control integrated circuit. So if other control functions are working ok this is likely to be good.
It is possible that other equipment can block the remote signal - if another remote controller is stuck on [jammed down a crack in the sofa] or if you use energy saving lamps in the same room - they can produce high levels of infra red noise.
Please take time to rate my assistance - I hope it is useful.
Mar 22, 2008 | LG 42PC3DC 42 in. Plasma HDTV
Tomtom GO 930 GPS Receiver Logo
51 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
