Question about General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
My refrigerator will not stay at 32 degrees, it is 57 degrees and I see ice in the back panel vents
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Refrigator freezing in bottom stays at 32 degrees
your damper vent door has most likely frozen in the fully open position and now all the cold air can get in from the freezer,its between the fridge and freezer compartments behind a plastic grille,if its frozen take a hand held hair dryer and carefully de-ice it so it can open and close again
May 10, 2010 | Dometic RM2652 Refrigerator
Ice is building up in the refrigerator vents
check to see if it is level front to back and side to side if not level the ice maker can run over the back and down on coil, you can use a hair dryer to defrost it s quicker. if digital set refrigerator to 38 degrees. you may have problem with defrost control.
Mar 02, 2018 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Kitchen Aid KSCS25INSS will defrost the freezer up to 57 degrees sometimes twice a day. I cannot use the ice maker because I end up with a large block of ice after one or two days.
57 degrees is pretty hot. If it occurs on a regular basis day to day, it sounds like a defrost cycle malfunction.
There is a calrod heater imbedded in the evaporator coil behind the panel in the freezer compartment. It comes on approx. 2 times a day. The compressor is shut off and the calrod (which looks a lot like the bake element in an electric range) is turned on. It gets quite hot, but a thermostat mounted on top of the evaporator coil, shuts the heater down when the coil reaches approx 50 degrees. If this thermostat ( often called a limiter ) fails to open in time, the temperature in the freezer coil box can easily reach 100 degrees or more. If so, this could be your problem. Remove the rear panel in the freezer compartment aand locate this small disc thermostat and replace with new.
Oct 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
The refrigerator had a blinking message to clean condenser. We vacuumed that and turn the unit totally off and restarted it. The temperature is at 57 degrees inside the refrigerator. What do we do?
Remove shelves and check if there is a small frost or ice buildup on one of the corners of the back panel. If there is - there is likely a problem with the sealed system (freon leaked out)
Oct 13, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Samsung 2556 refer
I had the same problem, I removed the shelves and the lower panel behind the shelves...Behind it their was a radiator like contraption, it was ENGULFED WITH ICE......I used a hair dryer to melt the Ice , and the problem went away....Thats all I can offer you...
May 06, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refrigerator will not stay cold
Bought a second hand fridge that was running well. We layed the fridge on it's side for moving and let it stand upright for at least 4 hours. The moving was only 45 minutes. The freezer is semi-cold but the main body of the fridge stays at aprox. 68 degrees. Any solutions.
Oct 31, 2007 | Refrigerators
General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
57 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a General Refrigerator Expert? Answer questions, earn points and help others
