Question about Water Heaters
Manage my life com sears
We installed a Kenmore electric water heater model # 153.326464. The waterheater has 2 pipes on the toop one for cold and one for hot. In the pipes when we took it out of the box ther were blue plastic inserts in each pipe. We left them in when we installed it. We are haveing problems with gettin water pressure from hot water. Should we have taken out the inserts? They did not look like they should come out.
muttandjeff
  • 359 Answers
SOURCE: Water heater ground
run to breaker panel or drive a 8ft ground rod and connect to it the water line is no longer acceptable as the public utility's are using pvc for gas and water now and this is no longer a practice you could use the ground rod that is already installed on your service and use connector , but something you might do well to check is to make sure in the process of installing the plastic pipes the ground going to the panel was not also disrupted if so you will need to install 2 8ft ground rods at least 6 ft apart and daisey chain together with proper size ground wire . # 4 solid for 200 amp and # 6 solid for 100 amp service , I would make sure the panel ground is solid very important for safety ,, let me know if i can further assist
Posted on Feb 07, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: I have water pouring out of a pipe outside that is
That pipe is connected to something called the T&P (temperature and pressure) relief valve. The pipe that connects to the valve should be run to a drain line so that the water goes somewhere other than all over the floor, but often it just ends a couple of feet from the valve. It's possible the valve has opened because the pressure in the tank is over its limit, but more likely it's the valve's fault. If the new heater was supplied without a T&P, the installer may have used the one from your old heater. Over time the spring inside the valve weakens. Then it can't hold the pressure from the new heater properly. A new valve is under $10 at home improvement stores or larger hardware stores. It just screws into the water heater, so it's simple to replace it if you have a pipe wrench. Turn off the water into the heater and remove the old valve. Use Teflon tape or pipe dope on the threads of the new valve (the store will sell that too), tighten it into the heater, then turn the water back on. That should end your leak. If it doesn't and the T&P valve still opens, you'll need to have a plumber check the water pressure in your home.
Posted on Jul 07, 2009
SOURCE: Combi Boiler - Hot water pressure low
I have a 1 bed flat, above an old pub. I have a combi boiler but my water pressure is ridiculous. The shower water runns down the shower head. I'v been told that the cold water feed to the building is split to two boilers, one to the pub and one to me. Im thinking of installing a shower pump in between the boiler and the shower. will this work as my friend says he has done this and it sorted his problem out. I'v looked it up on the net and everything says this does not work. Help please.....
Posted on Dec 24, 2009
  • 185 Answers
SOURCE: I have a 40 gal
You will need an amp meter. I suspect that the lower heating element is out or the thermostat.
Most water heater have a upper and lower element. The bottom is the main work horse.
Take the lower access door off and you can get to the wires to use a clamp on Amp meter. You should get a reading of 10 + amp if it is working. You can check the thermostat with the volt meter also to make sure you are getting voltage to the element . You should have 220 volts across the two wire attached to the element. The elements are not to hard to change. You will need to shut the power Off and the Cold Water off. Drain the tank to get below the bottom element and you will need to get a special wrench to unscrew the old element out of the tank. Hope this Helps
Posted on Jan 02, 2011
Testimonial: "Thanks for the promt reply, I had the feeling it might be that but did not know how to find out. Thanks again"
heatman101
  • 43501 Answers
SOURCE: Kenmore Economizer 6 Gas Water
A few things...
Fisrt off these pressure switches are very sensitive instruments and work on VERY small pressures. so it they wear just a bit they fail to work.. this insures maximum safety. So if all else checks out replace the pressure switch, they fail often, but it is the only way to run these things safely.
Also check all the tubing going to the pressure switch for moisture... just a few drops of water and cause them not to work...
When you start the unit... jumper the pressure switch with in the five second window and see if it lights... is is does then you know for sure the problem is there...if not then the problem could be in the control board.
If you own and know how to use an OHM meter you also can check the switch with the unit running to make sure the contacts are closing.
Bottom line... I think you have a bad pressure switch, but check out everything else first before replacing it.
heatman101
Posted on Aug 17, 2011
Tip
Find your only getting Luke warm water @ your faucets??
This is a common fault with new to used installed waterheater.
It is call a diptube ,made of pvc in part description. It is located on cold inlet,top of waterheater.
Malfunction of dip tube is usually a fracture caused by age mostly,or faulty install when new and tube was exposed to high heat from welding .
This tube allows the cold water supply to flow into W/heater and exit at bottom where it is heated while pushing already heated water to hot side and to your faucet. If this tube is defective ei...cracked the cold will [leak] mix with the hot before reaching bottom to be heat..thus lukewarm water syndrome. Solution $8 part H/depot>remove coldside copper fittings and pull white pvc out,about 4feet long,less rotted area, install new 3/4 inch pvc dip tube with flange up.
Thanks jj505 The HomeRepairman
jthomefix@gmail.com
on Apr 13, 2009 | General Electric GE SmartWater Household...
How to how to install the anode rod - for extended warranty - in a new Rheem waterheater?
You are installing a combo anode rod that replaces hot water outlet nipple. This means you will have 2 anode rods, which doubles the anode capacity of tank, which can cause extended life of water heater, assuming that both anodes are inspected each 2-5 years.
Sounds like a heat trap insert is in the way.
Look at parts sheet that comes with product manual.
Pull insert out since it will cause clogs.
Same insert is on cold side nipple.
I want you to contact the Tank forum since they are anode experts:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Tank will recommend magnesium anode and not aluminum.
My understanding is that Rheem water heaters are made so only Rheem brand anodes fit their tanks. While other companies use generic anodes that are sold at any plumbing supply, and also sold at Tank website.
You can configure pipes to make heat traps that save save $2-4 per year on gas water heater operation.
http://waterheatertimer.org/images/Heat-trap-install-900.jpg
http://waterheatertimer.org/How-to-maintain-water-heater.html
Sep 08, 2012 | Water Heaters
Where is water shut off valve for Rheem 40 gal electric water heater?
The water does not have a shutoff valve. The valve should have been separately installed, usually directly above the water heater on the cold water line.
Gary
Sep 25, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
30 galons gas direct fired water heater.\r\nI get hot water for 2 minutes, then water gets cold
The dip tube on the cold water side either is not there or it is broken off then the cold water stays on the top and gives cold water quickly...
If this is a new installation then check that the piping is correct and that the cold and hot pipes are not switched...
heatman101
Feb 02, 2011 | General Electric Water Heaters
Rheem water heater model #82V661 serial # RH0106D11663 leaking water at lower panel. Water is coming from above wiring and control panel. Is this fixable or need to be replaced? Mfg date is 01/2006
You have 240volt electric water heater
Check both elements for leaking.
Check top of tank for leaking pipes.
If water heater is leaking from side of tank, then tank is rusted out and could rupture.
This tank must be replaced.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
My friend welded his tank to get more life out of tank, but he assumed the risk.
Hot water heaters are under pressure from heated water which expands.
If tank ruptures, water will flood out of tank and water will run until shut-off is turned OFF.
This causes major damage inside home.
Protect yourself first, and then let's talk more.
1) Turn off water at shut off located on cold water line above tank.
2) Turn off power to water heater:
Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON.
Electric heater, turn off circuit breaker.
3) Open tub spout on hot side and let run a bit to relieve pressure.
4) Now your property is safe.
You can limp along with failed heater if leak is slow.
Turn heater ON when you need hot water.
Typical Gas heater makes 41 gallons hot water per hour.
Typical Electric heater makes 21 gallons hot water.
Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water.
http://waterheatertimer.org/images/Water-heater-reference-guide-2.jpg
If you are going to install heater yourself:
Look at label on side of old tank to identify size and particulars.
I buy ordinary heaters from Lowes and Home Depot and always buy scratch-n-dent models when possible, because superficial damage to outer tank does not lower lifespan of heaters I have installed.
Buy same size heater if it worked fine before.
Buy new flexible water connectors.
Set water heater in drip pan.
Offer 10% less than price shown. Make them deal with you. Shop Ace hardware, Lowes, Home Depot. Kick the tires since you have a bit of time.
I know you have electric heater, but many folks read these answers, so I include info on gas too.
#1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit if you encounter 1 repair. Electric tankless heaters require larger electric service box. Gas tankless require larger gas line (larger gas line, more gas consumption, bigger bill unless you cut consumption)
2) How to install gas heater:
http://waterheatertimer.org/How-to-replace-gas-water-heater.html
3) How to install electric heater:
Read link above because many of same steps apply to electric.
The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in circle so it fits inside dip pan. Wrap entire electric heater with insulation blanket, except don't cover TP valve.
4) Connect bare copper jumper wire between hot and cold pipes to prevent stray current corrosion which will shorten life of tank. Make sure cold water line is grounded.
Also read:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
Jan 07, 2011 | Rheem Water Heaters
My water heater is leaking a lot. water comes from the down bellow. It started like three months ago but it is getting worst Do I need to replace it? how much it will cost a similar one?
It sounds like you need to replace it, Actual cost can very widrly depending on your location but I would say $350-400 is probably close. Plus installation unless you can do it yourself. Hope this helps. Thanks
Nov 23, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I want to buy an anode rod for my whirlpool water heater. Mod # E2F80HD045V. Cannot find the part number.
The part you need is actually the following as it was made for Whirlpool by AMERICAN WATERHEATERS:
Part for AMERICAN WATERHEATERS, Model # E2F80HD045V
Number: 4710185 Category: Plumbing and Heating Length: 53.90 Width: 1.10 Height: 1.00 It is sold by Sears and is available for $17.99.
Good luck with your repair!
Mar 13, 2010 | Whirlpool Water Heaters
Have no hot water flowing at all from my Atwood hot water heater. cold ok tank full?
Hi and welcome to Fixya.
Here are 2 manuals that should help you in troubleshooting your RV hot water problem.
Multiple times there is a ref. to resetting the reset switch for 30 seconds on the unit (cover removal required)
For the ignition:
http://www.atwoodmobile.com/manuals/waterheaters/MPD%2093757%20PS%2011.19.07.pdf
For the water heater:
http://www.atwoodmobile.com/manuals/waterheaters/MPD%2093050%20PS%204.9.09.pdf
The manuals as written are full of warnings mixed in with meaningful text. (Not user friendly)
Feb 02, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heaters Logo
54 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
