Question about Carlon Wireless Doorbell system with volume switch
Model RC8233R battery - Carlon Wireless Doorbell system with volume switch
I have a Carlon RC8233R plug in chime with multiple door bells and different chimes. The doorbells have started intermittently ringing without being pressed. Would you know the cause of this? Thanks
Hello Laurie DeLisi,
If you live in the NORTHERN Hemisphere...
my best guess would be RAIN-WATER...
Dismount the unit and bring it inside... Open it and look
for moisture...
Then look at the instructions and see if the BUTTONS
ARE SUITABLE FOR wet locations...
ELSE
You have a NEAR Neighbor... with conflicting radio signals
(just guessing here)
Carnac the Magnificent
Nov 28, 2017 | Carlon Home Security
Tip
How to put higher capacity battery into old Nokia Mobile Phones
As we all want longer stand-by and talking times with our mobile phones and sometimes get problems to get an original battery for our old Nokias, here is a tip for this matter:
Most of the former Nokia mobile phones use the battery with the model type number "BL-4C". There are some models using type "BL-5C". This "5C" model has more capacity and could also be used instead of the "4C" model. The 5C model is slightly fatter than the 4C one.
Using BL-5C needs with some Nokia mobile phone models a little modification (like 6100) while others do not (like 6260) and require a bit harder close of the battery lid. Cutting both edges on the batteries sides to fitting in the battery compartment is easy done. Charging process is not influenced and works accurate.
on Feb 28, 2011 | Cell Phones
What is the replacement model number for Carlon RC8233R door chime?
Http://www.carlonchimes.us/ccus-wireless-plugin-chimes.htm
You could look here
Cheers
Sir John Dana Hamilton Taylor
IQ 397
Apr 24, 2017 | Cars & Trucks
How do i add a second switch to my rc8233r?
I would try Ebay first (or search the net for availability and prices). I bought CR2032 3V Button Cell (that are used in my Carlon door chime buttons) batteries. I got 10 for under $5. Carlon (Thomas & Betts) still makes a variety of door chimes and accessories. However, on their site, the prices are atrocious. But, I think that Thomas & Betts deals in bulk (as in dealing with retailers). Because they list their items in bulk price form. I personally have 5 T&B wireless door chimes. Hence, 4 of the buttons are in storage. Out of curiosity, I tried all of them. All 4 extra buttons rang all the door chimes. Caution, on the packages of the door "chimes" I purchased. There's a blurb on there that states the wireless buttons for the "door chimes" will not work with the "doorbells". If you have the packaging for the one you have. It will explain. I'm not positive, but it seems the variance is due to whether you use battery or electric powered models. Hope I was of assistance...Greg
Jul 20, 2014 | Carlon Wireless Doorbell system with...
How do I replace a macbook pro battery?
On older models, there is a round lock that you turn 90 degrees to release the battery. Use a coin, and it should turn fairly easily. You can order a battery specific to your model from various electronics supply houses.
On newer models, you cannot open the case. You must return the laptop to Apple, and they will replace it for a set fee. It varies with model, but the cost includes battery replacement, shipping, battery recycling, and a new warranty for the battery.
Jul 18, 2014 | Apple MacBook Pro Notebook
Need manual for rival soft serve ice cream maker model 8150
Rival doesn't have the model 8150 listed, but here's the model 8151 manual. Maybe it will be close enough to help.
Aug 07, 2011 | Rival Soft Serve 1.5 Quart Ice Cream Maker
What does Inval Battery mean when displayed on my screen?
This means your battery isn't properly inserted or the battery is not the specified battery for that phone model..
Open the user manual for your phone and look up the battery information. The exact battery model number is listed here. Compare the model number to the battery you are attempting to use. If the model number is different, you are using the wrong battery.
If you are sure you have the right battery,remove the battery case from the phone Look on the battery for a white piece of adhesive with installation instructions. On the adhesive it states which side should be facing away from the phone.
Slide the battery into the phone following the instructions given on the battery. If you attempt to slide the battery in upside-down or flipped over the phone is not going to power on.
Aug 31, 2010 | Motorola Mobility W315 Cellular Phone
How to change ring tone? Model #RC8233R Carlton wireless door chime
Mary, there is a small button on the face of the face of the pusher. With the unit plugged in, push that little button and it will play the next available ring tone. When you find one that you want to use, simply stop and that one will be what you hear when someone comes to the door.
Aug 20, 2010 | Audio Players & Recorders
Invalid battery
Have you changed to a new battery if so you have the wrong model battery all phones have particular model batteries and a few generic or aftermarket models that fit if it is original battery it could be buggered and needs to be replaced.
Jul 21, 2008 | Motorola Mobility E770 Cellular Phone
Carlon Wireless Doorbell system with volume switch Logo
318 people viewed this question
Top Carlon Home Security Experts
ray gallant
Are you a Carlon Home Security Expert? Answer questions, earn points and help others
