Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
M451 noise when printing - Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
How do i fix the error code f2-00 in AR-M351N copier
HI,
I assume you ran 25-02 when you changed the dev?, if not you will have to replace it again.
Check to make sure you have drive to the dev box, slide out dev box and rub your finger along mag roll and run it up, remove again and see if the dev has returned.
If it is a high mileage machine, you can get problems with the dev drive, the box itself or the toner sensor.
Cheers
Andy
Jan 24, 2015 | Sharp Toner Digital Copiers Ar M355 M351...
Shadow copy
Need a little more info but if you are using a laserjet printer shadows or duplicate images usually come from worn out rollers in your fuser. Depending on your model fusers are available by themselves or as part of a maintenance kit. Replace the fuser and that should take care of the problem.
Nov 02, 2013 | Sharp Toner Digital Copiers Ar M355 M351...
Can't install HP M451
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Apr 11, 2013 | Office Equipment & Supplies
Easy share M451 will only work when plugged in, have fitted a new battery
Hello Susan, I thought I just answered this question ? Well I guess I will answer it again. Sounds like contact problems inside the camera. Look inside for anything obvious, normally corrosion or contact damage. Hope this helps.
Best Regards, Russell
Jan 06, 2013 | Kodak Cameras
Printer made machine gun noise. will not print.
The print head is stuck - something has jammed it and the noise you are hearing is the carriage for the print head. Open the top and try moving the head by head sideways to see what has jammed it.
Aug 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
