Ecoquest Fresh Air Air Purifier
Fresh-air purifier does not geenerate ozone
shared by 2 users
posted by jjvors on Nov 04, 2007
A couple of weeks ago our Fresh-aire purifier stopped working. The UV light, which we had replaced still shone, but no ozone was generated. Also, the status screen was blank--it no longer showed the fan level or the ozone level.
Do you have any suggestions? Coiuld this be a fuse problem?
Thanks,
Jeff
jjvors@sbcglobal.net
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by scotty8672 on Nov 30, 2007
Never had a problem with my new machine 6 months old. I turned it off for a montha dn wehn I went back to use it the frant screen only flashes and shuts off. The fan and bulb don't even try to start.
If the bulb is bad will the fan not start and panel shut down while trying to start?
Please help.
ftlaud1@hotmail.com
Best Solution
posted on Dec 22, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I ended up sending our machine in to be fixed. The problem was a corroded anode plate, which damaged other circuitry.
Check your fuse, ftlaud1. Make sure your machine is clean.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Fresh-air purifier does not geenerate ozone:
I don't want to Accept this solution
Solution #2
Thanks for Trying (70)
Controls Eng
Rating: 70%, 2 votes
The fan is bad it should blow the fuse, I believe that the mother board has a problem, or the Display board may have gone bad.
Thank You!
Solution #3
posted on Dec 27, 2007
ekwade
Rating: 85%, 2 votes
If the machine is still under warranty (5yrs), then call their toll-free number to get a fix over the phone: 1-800-989-2299
Thank You!
Can you Help with these Air Purifiers problems?
Ecoquest  fresh air 2.0. unit cycles on and off in...
All the letters has disappeared on the panel and it has...
I have Ecoquest Fresh Air US40135b. After cleaning...
I have an older Fresh Air (2004 model) which has been off...
It isn't broken but doesn't have the same guts as it once...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Air Purifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
