Question about Siemens Microwave Ovens
Why is my siemens oven failing to turn off - Siemens Microwave Ovens
Hi I have a siemens inno-wave HF17055GB Microwave and the plate turner is not turning, otherwise it seems to be working? help please
Replace the motor. The teeth in its gearbox have probably been damaged when trying to turn the plate by hand.
Aug 25, 2014 | Siemens HF17055GB Microwave Oven
How to fix siemens microwave oven
replace the fuse inside will be a 10 AMP type
use the correct type look on it for numbers and also size it up
get them from ebay
then replace the 'de-fuser' plate inside
its a flat panel made from silver mica you need just usually to remove a screw
most often a hole appears and it turns to carbon then it starts too cause problems and the fuse fails
or someone puts a metals something in it
so take the top off find the fuse and replace it and check the mains supply fuse on the cord plug
good luck be safe and use the right type of fuse
Aug 13, 2014 | Siemens Microwave Ovens
Siemens Innowave 'n890l6u5 rsgs'
sadly you destroyed the unit only option is replacement of same
Aug 11, 2017 | Siemens Microwave Ovens
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Hello, I have a microwave Siemens HF 66051.The oven is working perfect,but the microwave doesn't.The fuses are well. Do you have any idea?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a proffessional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 03, 2011 | Siemens HB77L65GB 900 Watts Convection /...
Our microwave oven turns on but makes a loud vibrating sound and does not seem to heat anything put in it. Does this sound like the tube that just went bad??
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 07, 2010 | Siemens HF87950GB Convection Microwave...
Siemens hf36v305 microwave contol panel does not work. Ir keeps doing what ever it wants. Reseting by removing power and plugging in again has very little effect. Control panel fails to work as desired.
I would call them at 1-888-4-SIEMENS or visit the support / customer service links at siemens-home.com
It may possibly have a shorting keypad or moisture or grease in the controls.
Please let us know what you find out so we can help other owners!
Oct 05, 2008 | Microwave Ovens
Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Dec 08, 2007 | Siemens HF87950GB Convection Microwave...
Microwave Ovens Logo
90 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
