Question about Cell Phones
Factory data reset code for samsung gs7562
Freezes up
Why does my Samsung galaxy centura freeze up overtime I try to log on to Facebook and runs slow all of the time?
Your Samsung runs slow all of the time because it has only 512 MB Ram and a single core cpu. You can install clean master from google play and run it or you can do a factory reset(! you wiil lost your data if you do this Menu" -> "System settings" -> "Backup & reset" -> "Factory data reset").
Nov 19, 2015 | Samsung Cell Phones
User fault not kernel panic upload mode
From the Samsung GT-S5300 user manual -
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close applications or reset the device to regain functionality. If your device is still responsive and an application is frozen, close the application with the task manager. If your device is frozen and unresponsive, press and hold the Power key for 8-10 seconds. If this problem persists, perform a factory data reset. In the application list, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
See Troubleshooting section (pg 109) -
http://bit.ly/1Pqin8c
May 07, 2015 | Samsung GT-S5300 Galaxy Pocket
How to unlock screen, when code number is lost?
Reset LG G2x P999 to Restore Factory Default Settings
How to hard reset (factory reset) the LG G2x P999?
There are two different ways you can reset your LG G2x P999 to its factory default settings, via settings menu and using phone buttons. WARNING!!! If a factory reset (hard reset) is performed, all installed application and user data such as messages, phone contacts, image, video and audio files will be erased. Please remember to back up any important data before performing a factory reset.
Reset LG G2x P999 using Settings Menu
  1. From the Home screen, press the Menu Key .
  2. Touch Settings > Privacy > Factory data reset.
  3. Read the warning and touch Reset phone.
  4. Touch Erase everything.
Reset LG G2x P999 using Phone Buttons
  1. Turn the power off.
  2. Press and hold the following keys at the same time for 15 seconds: Home Key+ Power Key + Down Volume Key.
  3. When the LG logo is displayed, release the keys. The phone will turn on and
    perform a factory reset immediately.
Resetting the phone does not erase any system software updates you have downloaded or any files on your microSD card.
Mar 26, 2015 | LG G2x / Optimus 2X 4G Android T-Mobi8GB...
Forgot password samsung GT-C6712 ...How to open it?
If you forgot your phone code, what you can do is to have a hard reset. Hard reset means restoring the phone back to its original factory settings. if you do not do a factory reset, then you cannot change the code. It is the only way that you can change it. But on the other hand, this method deletes everything that you have saved in your phone memory. Including images, contacts, videos and everything on your phone memory. To do a hard reset on your Samsung GT-C6712, do the following steps:
1. Turn on your phone.
2. Open your dialer/dial pad.
3. Type: *2767*3855#
4. If there will be a confirmation message, just choose Yes.
5. Wait for the process to finish.
Note Use the code on your own Risk
you will lose all the contacts and private data
Note: After the hard reset, your phone will automatically reboot itself. If your device freezes after doing a hard reset, just do this:
Nov 24, 2014 | Samsung Gt-C6712
Phone freeze
Did you install any new application. Try doing a hard reset which will bring your phone to factory settings. You will loose all your contacts and data on phone. Please refer to this link on how to hard reset your phone.
Samsung S5260 Star II hard reset
Apr 05, 2014 | Samsung Lands Phones
Note 8 still freezes on startup screen after factory reset
you should call to company where you have bought or even better to go in with it
Mar 23, 2014 | Samsung Galaxy Note GT-N5110 16 GB Tablet...
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storageā€¢ : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
Samsung galaxy S2 is freezing and wont take a charge or sometimes randomly says its charging when its not even plugged in. can I just factory reset it?
Yes you can factory reset it. There is an option in the settings menu, usually under the data submenu. It will be titles "Factory Reset" or "Factory Data Reset" or something similar.
Nov 04, 2013 | Cell Phones
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
