Question about Tomtom GO 930 GPS Receiver
Blaupunkt RC infra-red remote contro - Tomtom GO 930 GPS Receiver
Onkyo tx ds777 remote does not working
If battery replacement does not work, your remote control probably has failed.
Dec 20, 2017 | Onkyo Audio Players & Recorders
Onkyo RC-738M remote control mute does not work and volume control is intermittent. How to fix?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
If the remote control is found OK; check it with set it up to an other set-up code said for your TV. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 05, 2014 | Onkyo Televison & Video
Theres no signal. I follow the instruction in manual. Buts its not work astron tv rc-1432? Pls help.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Nov 19, 2014 | Televison & Video
What is the code for a yamaha dsp -ax 620receiver codes
PS3 BD remote is Bluetooth, not infra red. Bluetooth and Infra red are two different ways of transmitting signals. They are not cross-compatible. So there's no code to allow a PS3 BD remote to operate any Infra red device becuase the PS3 BD remote does not issue IR commands.
Aug 17, 2014 | Audio Players & Recorders
Ah59 02298a
Check the remote control for its infra-red emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, check this link http://electronicshelponline.blogspot.com/
If you wish to get more details about set-up codes and others, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 23, 2013 | Televison & Video
Remote does not respond to any function, tv is on and cannot change chanel or anything, frozen
you need to check the battery contact with the battery terminal make sure that the terminal is clean.
check open the cover of your remote and check the solder of the battery terminal from the pcb board use a soldering iron resolder it.
using your cellphone camera test the infra red emmision of your remote control aim the camera to the infra red of your remote.you must see at the screen of the camera that the infra red is lit when any button is pressed..if not the infra red is busted.
using your cellphone camera again to test the infra red emmision of your TV. Aim the camera to the infra red of your TV.you must see at the screen of the camera that the infra red is illuminating.if not the infra red sensor of the TV is busted.
Jun 21, 2011 | Universal Remote Control MX-3000 LCD...
Remote doesn't work
Check your remote batt first. if batt are new, check infra red light from remote using camera (selular cam etc). If infra red flashed on cam, that indicate remote is no problem. Call technician to check your tv.
Mar 24, 2011 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Not responding after changing old battery
Sep 10, 2010 | Samsung TV Remote Control
Remote wont operate sound dock.
hi , To check wether the remote is outputting a infra red signal when a button is pressed try viewing the little LED at the top of the remote through your mobile phones camera , these little cameras pick up a fuller spectrum of light and you should see if flickering. IF you dont then check the batterys/. then the connectors for acid errosion from previous leaking batterys./pull the remote apart and with a pencil rubber clean the contacts on the surface of the circuit board/.The rubber membrain that has the buttons on wash it with warm soapy water , dry thouroughly.last test --go to mapplins and buy a replacement infra red led and change that? , see haow you go whith these tips and report back
Mar 20, 2009 | Bose RC-18S Remote Control
I have a problem with my denon rc 8000 remote
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jun 06, 2017 | Denon RC-8000 LCD Touchscreen Remote...
Tomtom GO 930 GPS Receiver Logo
14 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
