Question about Dryers
My gm1620 heat press rocker switch is getting to much heat an it stops working an i have 2 replace it.an i can not find any kind of info that is of any help 2 me anywhere.on what could b making it happen.or the kind of fuse it i need.
2 Suggested Answers
  • 686 Answers
SOURCE: dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Posted on Mar 06, 2009
How can i remove error code c 448 in toshiba e studio 5540c
Step 1: Remove all the paper that is jammed in the machine. Follow the steps on the touch screen to locate the jammed paper.
Step 2: Turn off the copier with the power rocker switch on the right side.
Step 3: Hold down the 8 and 0 on the numeric keypad while turning the machine back on.
Step 4: Enter 400 on the numeric keypad and then press the Start (copy) button. As you type the 400 will show up in place of the D
Step 5: Enter 0 on the numeric keypad and then press the "Enter" button on the touch screen.
Step 6: Power down the machine with the same power rocker switch as in Step 2.
Step 7: Turn on the machine with the power rocker switch.
Dec 31, 2015 | Toshiba Office Equipment & Supplies
I have a 2 year old LG DLE5001w dryer. It stoped heating heater element replaced on 11/21/14. Worked 2 loads stopped heating, replaced switch, worked 3 loads stopped heating replaced thermostats. Did
Most Dryers has a thermal switch that when the air flow gets so hot it will shut down the dryer until it cools down or on some models the thermal switch has to be replaced .. The most common problem to cause this is a restricted air flow somewhere in the exhaust of the heated air causing the dryer to reach too high of temp, which could cause a fire .. Hope this information is help full......
Dec 29, 2014 | LG DLE5001W Dryer
The hw/ hw+ch rocker switch on my danfoss set 2e heating programmer is not working
Rocker switch stuck on replace programmer or diverter valve stuck in ch postion .
Aug 13, 2012 | Heating & Cooling
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
My Electrolux Epic 6500 SR will not turn off by pressing on the switch button. I took it apart and removed the switch assy. I can maunually turn it off & on by pressing the rocker arm on the switch...
WOW !!! Finally You are dead on, absolutely 100%.... good work!!!.
Get only a genuine new switch button with spring from an AERUS Electrolux dealer and reinstall.
Then carefully reassemble the entire body and wiring harness.
Congratulations getting there.... you rate as an honorary technical genius in my book,...Your wife should be bragging about you to her friends. I am genuinely impressed and I`ve been fixing these since 1990. I bow in your presence.
PS while youre in there, check the rocker for evidence of fatigue, it is the more common issue
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
Oct 27, 2009 | Lutron Maestro 600-Watt Multi-location...
The front AC Just stopped in the middle of the day.
sounds like if you can wiggle the switch and it comes on then you need to replace the switch and I would try to find one in the junk yard first. They are usualy simple to replace as well . just google all info you can on diagrams. or get the dealer to give you a print out.
Jun 08, 2009 | 2003 Kia Sedona
JVC Gr-DVm50 switch/button broke
To fix the problem you need to replace 2 parts. The first part is the centre round rocker switch and the other part is inside the camera. It looks like a very thin, flat round aluminum disc.
The disc has 5 holes in it that matches up the with the small black points on the back of the round rocker switch. It's a very bad design fault with the camera because how it's held in place is simply a matter of aliening the rocker switch black points with the five holes you can see and push it in tight.
After years of use the five plastic points wear down and become to thin because of all of the moment or the holes they fit into gets worn out and then there is no contact for the rocker switch to be held in place.
Hope that make sense
Dec 30, 2007 | JVC GR-DVM50 Camcorder
Dryers Logo
18 people viewed this question
Top Dryers Experts
