Question about Bandwagon Furniture
What is the defintion of bandwagon - Bandwagon Furniture
Been having all sorts of problems since it's been out of warranty. What I'd like to know is does my model KP-57WS500 fall under the Sony recall?
Recall, Hardly
But you might be interested in this information. Click here
You cannot ask Sony to take the Tv back but you might want to jump on the bandwagon if you still have time?
Thanks for using fixya.com we hope this was Very helpful
Jan 25, 2011 | Sony KP-57WS500 57" Rear Projection...
Tip
What causes Windows Defender Update Error 0x80070422
If you have disabled either of the two following Windows Services then you will get the Update Error as shown below
This is the screen that you will see when Windows Defender tries to update the defintions file
You can enable both of these using the services.msc from the command prompt or use this TWEAK from my Sky Drive
YOU WILL NEED TO RESTART YOUR PC AFTER YOU IMPORT THE TWEAK TO LET THESE SERVICES START AUTOMATICALLY
If access to Windows Update has been disabled in the registry then you will need to use THIS tweak to ensure that you can prevent the 0x80070422 error
If all else fails then you can always download the latest defintion file mpas-fe.exe from the windows website HERE
on Apr 01, 2010 | Microsoft Windows XP Professional for PC
Tip
Re-Create your original NAV2008 non boot CD adding the latest Virus Defintions
This will re-create your original Norton Antivirus Install CD with the latest virus definitions by replacing the bundled 32 and 64 bit versions with the latest. I recommend that you use a CD-RW and update it as often as you can new defintion i32 files come out almost every day
The install requires a valid serial so unless you have one don't bother
You can also download a bootable CD version of NAV2008 to scan your PC if you have a valid serial number is at v1.4.3.38 and contains the definitions for the 29th August 2008 search the internet for NAV RECOVERY x86 SKU 14139706, I use it sometimes however I prefer to use Ghost v14.0 with my Updated Virus Defintions CD.
http://www.fixya.com/support/r3561871-automatically_create_an_update_virus_def
This is also worth a read from the norton website, this descibes how to use the WAIK to update the NRD for 2009 you will need the serial number to make this work as I don't have it I have not done this yet as I have now moved to SKY ISP and I get McAfee for 12mths for free.
http://community.norton.com/norton/attachments/norton/uploads/42/2/MakeNewNRD.pdf
Here is the link for the NRD on their ftp site you must have a valid serial for the NAV2009 to use this so If you don't either buy one or don't its up to you.
ftp://ftp.symantec.com/public/english_us_canada/recovery/2009/NAV/recovery_nav_x86.iso
on Dec 03, 2009 | Computers & Internet
How can i install antivirus
You can purchase a cd installer from the computer shop or you could search from the internet famous antiviruses like Norton, AVG, AVIRA, Kasperksy, Mcafee, NOD32, or Avast.
Jan 05, 2010 | Dell Dimension 3100 PC Desktop
The picture seems very coarse and has diamonds running across it
Hello: In standard defintion the picture is showing in 480p which is the lowest resolution for LCD televisions, The picture will only look as good as the signal its getting, If you have cable then it should look some what better even with std defintion. The Diamonds/triangles are caused from a weak digital signal or weak broadcast station. This is a normal occurance for LCD televisions as the picture is put on the screen in blocks. I would not say your television is bad, just a poor or weak signal, If you are using a digital antenna and not cable, then you might try purchasing a signal amplifier to boost the signal before going into the set.
Nov 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Tip
Automatically create an Update Virus Defintions CD for Norton Ghost v12.0 and...
Got Symantec GHOST12 (bootable CD) + NAV2008 (non-Bootable) with a valid serial number and want a method to scan your PC for Virus with the latest Virus Defintions but you don't have NAV2008 installed because your ISP gived you a free Virus Suite then read on.
I have created this semi-automatic method to create a virus CD that will work with the Scan for Virus option on the Ghost Boot CD simply replace the Ghost CD with the one this creates and select browse usually for D: drive you will see your CD-ROM access light action as the Ghost loaded on Ram disk updates itself.
Download link for the Norton Ghost definitions Updater is HERE you need to join my group on facebook @windowstipsclub.com to request the password to unzip as this was originally posted there first, though you FixYa's might like it too plus there are other great tips and tricks. The download link for my Norton AV2008 definitions install CD is HERE on my rapidshare due to a 50MB upload limit on my Sky Drive.
You may also need to enable Windows Scripting Hosts do this using THIS from my Sky Drive to enable the VBS script to run at the start of both autoupdaters.
CreateUpdateVirusCD.bat - Will download the latest i32 definitions file and then action the full unzip ISO and burn in one go if you already have the ISO created then you can run the file below. first it will allow you to run a vbs script to clean then temp files Ihave found this to be required on some systems before the downloadsucks in the latest i32 definition file from the FTP server it willthen unzip it and create a Update Locator Virus Definition folder on your desktop similar to the UPDTLCTR.EXE function that is bundled with the Ghost CD (this only works if you have NAV2008 pre-installed and can't create the folder otherwise)
makecd4defs32.bat - will create an ISO from the Desktop Folder and burn the CD for you using mkisofs.exe and parts of the CYGWIN dll's this will burn the ISO to your CD/DVD burner it is set to default scsibus1 (dev=1,0,0) if your burner is on a different channel then you can run scanbus note the number and edit the listmem32.awk by altering the numbers shown in bold and saving the changes, if your drive is on scscibus2 then change to 2,0,0 and so on...
print "cdrecord speed=0 -dev=1,0,0 -dao -v Virusdef.iso" >> "dumpit.bat"
In the case of this scanbus the CDRW is located on scsibus1 but connected at 1,1,0 so change the line to read.
print "cdrecord speed=0 -dev=1,1,0 -dao -v Virusdef.iso" >> "dumpit.bat"
Norton Ghost v12.0 ( includes defintions no later than 2007)
Norton Ghost v14.0 ( includes defintions no later than 2008)
At time of posting the latest intelligent updater defintions file is 20091202-006-i32.exe which includes definitions not later than 2/12/2009 this can now be used in conjunction with your Bootable Ghost CD to give your PC an up-to-date scan using the latest protection
Last note you will have to create the desktop file if you have not tried to run the original update file from the Ghost CD otherwise the script will fail feel free to add these line to the script if you wish that is if you can get the mkdir command to create the Update Locator Virus Defintions folder.
on Dec 02, 2009 | Computers & Internet
Filter cleaning
The fact is that the "bagless bandwagon" is powered by some excellent marketing that conceals what is often poor technology. In your case, the filter blocks because it's doing the job that a bag would do in a bagged machine (catching the dust), and then the machine overheats because the flow of cooling air to the motor is restricted. The only solution (for this machine) is to keep buying new filters - the only permanent solution is to buy a different vacuum cleaner. And my advice is to buy one with a bag!
Nov 03, 2009 | Dirt Devil M0105 Bagless Vacuum
Sound drivers for windows 2002 sp3 for 945 intel s
first u need a winows update called high defintion audio driver package for winows version u r using ... install that first and update ur high defintion audio device using realtek driver
Mar 30, 2009 | Intel Motherboard
Webroot spy sweeper
I did the live chat support. They were very helpful. Gave me a link to redownload the spysweeper product, since mine wouldnt let me do anything. It did work and my spysweeper is working great now. http://www.webroot.com/company/support/. Went to that site. requested a download and they sent it to my email right away.
Apr 06, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Could not locate a valid definitions file
it is your purchased version or u got it from your friend or somewhere else.
if u purchased it then u have to just go to that site and follow the instruction to get some updation.
or this is your unpurchased version than it is good to remove it.
for that go to control panal and then select add/remove hardware or software. in this option u will get all the softwares.
select spy sweeper and select remove option.
that will remove spysweeper.
thanks
Furniture Logo
449 people viewed this question
Top Bandwagon Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Bandwagon Furniture Expert? Answer questions, earn points and help others
