Question about Canon SELPHY CP720 Printer
Photo is printing with white line across the top.
I have used the cleaning stick again and again but it's made no difference. Is there anything else I can try?
  • 390 Answers
SOURCE: Lines across the tail end of small photos
Your printer sounds as if it has a hatred for one type of paper size!!! Seriously, it could be a positional blockage, ie debris in a place that allows large paper no worries, but as soon as it repositions itself to do 4x6 it catches a block. open unit if you can and thoroughly check for debris, ie papeer bits. Hope this helps. Also give your printer some tlc, clean heads, both manually with solution and cotton buds, and run print tests, clear print jobs memory, and try unconnecting and reconnecting cables, and powere supply.
Posted on Aug 11, 2007
cropp
  • 377 Answers
SOURCE: Streaks down middle of and rainbow colors on top of printed pictures
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
or you can use a hot water to clean surface of your catridge
Posted on Apr 21, 2008
freetek
  • 5568 Answers
SOURCE: White lines across text on Canon MX700
It sounds very much like a failed printhead or printhead driver; the circuit that controls which jet is addressed or left blank.
Posted on Feb 12, 2009
  • 5 Answers
SOURCE: Cannon IP4000 PIXMA - pink & green streaks
I've had the same problem with my ip4000, but the solution was to get a new print head. They can be quite costly, so I recommend the following:
1. Contact Cannon support and see if you can get them to send you a replacement. They sent me one free of charge, and didn't need an RMA for the old one, so it was hassle free.
2. You can always try to aggressively clean the head yourself by removing it and following some of the "home brew" procedures others have tried. However, you can damage the head further this way and it's only a last resort. Warm distilled water and a syringe was used by one person. When I tried this, it did not work at all, and I called Canon for the replacement anyway.
Posted on Feb 24, 2009
  • 739 Answers
SOURCE: white lines on photo
Take the cartridges out, then take the print-head out and run it under warm water for a few minutes. You could stand it in a saucer of warm water if you like - just the nozzles . Dry it thoroughly - use kitchen town and then refit it into the printer. Put the inks back in and then do some test prints.
It might take 2 or 3 goes but it should clear the blocked nozzle(s)
Inkjets like to be used - it keeps the nozzles clear.
Posted on Dec 31, 2009
Lines across photo when printed
If the lines are white you probably have clogged jets in the print heads. Try several head cleaning runs and see if that clears it.
Jan 29, 2011 | Epson Stylus 1400 InkJet Photo Printer
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Sep 24, 2010 | HP Office Equipment & Supplies
When printing photos especially A4 size my printer leaves white dotted lines across the photo
This is caused by the paper feed wheels (small spiked metal wheels to draw the paper through the printer.) Unfortunately, there is no way I know of to fix this, but you could try using different types of photo paper.
Aug 15, 2010 | Epson Stylus Photo R300 InkJet Printer
White line across photo
clean ur printer head. and check that if any air ur ink box
Jul 21, 2009 | Dell 540 Photo Thermal Printer
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
cx3200@tiscali.co.uk
Dec 17, 2007 | Epson Stylus R265 InkJet Photo Printer
White band on photo glossy output
Open printer, remove drum, clean laser lens with soft dry cloth, reinstall drum.
Manufacturer's Instructions
website: printer.konicaminolta.com
white vertical line (s) / how to clean the laser lens
Cleaning the printer. (5 pages)
Worked for me
Watemusic
Nov 13, 2007 | Minolta magicolor 2400W Laser Printer
White bands across printouts
Either one of the print heads are bad or a cartridge. This is what causes that problem. I know it is a hassle but I would take it back. If try and fix it you could void the warranty.
Mar 16, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon SELPHY  CP720 Printer Logo
old marine
old marine
