Question about Kyocera FS-C5030N Led Printer
Call service Code 4600 KYOCERA FS 8520 MFP
How can I fix our printer displaying a Call Service 4600 error message?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
Posted on Aug 06, 2014
  • 6 Answers
SOURCE: Kyocera Printer error - Help!
The code is for a defective cyan motor. So its either the cyan toner motor or a lump of toner inside the cyan toner container.
Posted on Aug 24, 2008
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
  • 241 Answers
SOURCE: I have a kyocera FS-2000D with error code: Call fo...
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
Posted on Jun 09, 2010
shawn38
  • 200 Answers
SOURCE: I HAVE A KYOCERA ECOSYS
The error indicates -
Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Posted on Jan 27, 2011
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
How to fix Error 900.43 service RIP soft ware
Reset Factory Defaults.
1. Turn off the printer.
2. Press and hold and .
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
If that does not fix this issue,With Error Code 900 displayed, press and . Post the complete list of Sub Error Codes on the display.
Jul 27, 2015 | IBM Infoprint 1532 Laser Printer
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • Oct 01, 2011 | HP LaserJet 4600 Printer
    Error 51.2 y hp color laserjet 4600
    Hi There, Please follow the below steps to fix this issue :
    Action : 1. Press the green (Select) button to continue. 2. Turn the printer off, and turn it on again.
    3. Perform a cold reset : a.Turn on the printer. b.Watch the control panel. c.When the memory starts counting, press and hold the (Select) button. d.Continue holding the (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady. e.Release the (Select) button when the Ready, Data, and Attention light are on steady. f.The control panel will display SELECT LANGUAGE . g.Press (Down Arrow) button once. The control panel will display COLD RESET . h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. 4. If this message persists, contact an HP-authorized service or support provider.
    Nov 08, 2010 | HP LaserJet 4600dn Color Printer
    Need to have 4600 laser printer in just black ,because of broken
    Sorry, my friend, there is no way to force it go B/W and override the error message.
    Sep 09, 2009 | HP LaserJet 4600dn Color Printer
    Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
    errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
    Aug 12, 2009 | HP LaserJet 4600 Printer
    HP 4600 printer with error message 51.2M and loud noise when calibrating. Any solution?
    Replace your magenta cartridge first. If the problem persist I strongly recommend a service tech. Error 51.2M is an magenta scanner(laser) error or DC controller.
    May 08, 2009 | HP LaserJet 4600 Printer
    A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
    Reference via HP Website, Click Here
    To Fix the problem:
    1. Press the green c00224695.jpg (Select) button to continue.
    3. Perform a cold reset.
    Mar 21, 2009 | HP LaserJet 4600 Printer
    Nikon coolpix 4600.
    Hi I found this info on the Nikon Australia website:
    "System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
    1. Use the memory card that originally came with your camera (or a Nikon approved card).
    2. Remove and replace the battery.
    On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
    1. Turn off the camera.
    3. Turn on the camera.
    If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
    Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
    Hope this helps.
    Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
    Kyocera FS-C5030N Led Printer Logo
    1,939 people viewed this question
    Top Kyocera Office Equipment & Supplies Experts
    Kyocera HP Expert
    Chris Schutte
    Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
