Question about Cameras
Hey my COOLPIX L620 wont turn on, even with new batteries, and the lens is stuck out. (I think, as it is new and I think it looks crooked.,)
2 Suggested Answers
  • 11967 Answers
SOURCE: My Nikon Coolpix S3000 has
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 07, 2010
Why would my flash stop working on my Nikon L620?
Settings on your flash is probably at Auto Mode. Change to manual and you can determine when to use the flash outdoors.
Aug 18, 2014 | Nikon COOLPIX L620 18.1 MP CMOS Digital...
My lens to my camera wont close when it is turned off,it doesnt even move when it is on. The screen just tells me to turn it off and on again, but that hasn't worked. Please help!!
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
Aug 02, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Lens error,,restart camera.,,the lens wont go back in ,,and the camera will not work,,,its like the lens is stuck,,,can any one help please!!!
Did you try replacing the batteries? If that's not the problem, then it might just be stuck. Look to see if the lens is a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
Aug 01, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Coolpix 4300 "system error"
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jun 07, 2009 | Nikon Coolpix 4300 Digital Camera
Lens stuck/lens error
Hello
there are tiny plastic gears inside and may have chipped or a small piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 19, 2008 | Nikon COOLPIX L10 Digital Camera
Jammed lens
Hey latyrant,
If the lens visibly looks crooked then the lens is probably broken and needs to be repaired by an authorized service technician. One thing you could try is placing the camera on a flat surface with the lens pointed up and holding the shutter button in, while doing this turn the camera on. Sometimes this will force the camera to try and focus before the camera can register the lens problem and sometimes it will force the lens back into alignment. If this doesn't work you could bring it to a Geek Squad® precinct in a Best Buy™ store and they could send it out to get looked at by a technician. I will say that the cost of digital camera repairs often exceed the value of the product. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 24, 2008 | Cameras
Two cameras and two lens erros
I don't think either camera is worth the over $100.00 that it will cost to fix. However, look at my posts on this problem of lens errors. By forcing gently the lens in or out when you start the camera and shut it off, it may get the lens to work again.
This may damage the camera even further, up to you, and may be worth a try.
Apr 11, 2008 | Nikon COOLPIX L3 Digital Camera
Camera lens stuck out and wont turn on
I purchased my Canon SD 1000 a couple months ago and as soon as I owned it one month I had lens problems. Stuck shut stuck open and now its still stuck open. I take care of my camera and carry it in a case all the time. This is my second rodeo and there wont be a 3rd,
CANON IS DONE GETTING MY MONEY
Jan 20, 2008 | Nikon COOLPIX L2 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Cameras Logo
432 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
