Question about Games
Shoreline area along ocean were water rises and falls
Where do starfish live?
They have been renamed 'Sea Stars'.
Where do starfish live? ' Reference.com
https://www.reference.com > Pets & Animals > Marine Life > Starfish
Starfish, which have been renamed sea stars, live in all areas of the oceans that cover the Earth. The most common form of starfish is the five-armed species that ...
Where do sea stars live? ' Reference.com
https://www.reference.com > Pets & Animals > Marine Life Also known as starfish, the more than 2,000 species of sea stars are found throughout the world's oceans. They live in a variety of ocean habitats, including bay bottoms, dock pilings, rocky shores, tide pools, cold seafloors and warm tropical waters.
What part of the ocean do starfish live in? ' Reference.com
https://www.reference.com > Pets & Animals > Marine Life > Starfish Starfish typically reside in shallow waters along rocky coasts, according to The Columbia Encyclopedia. The starfish is an echinoderm of the Asteroidae class.
How many starfish species are there?? Where do they Live?
echinoblog.blogspot.com/2013/04/how-many-starfish-species-are-there.html Apr 23, 2013 - All echinoderms, including sea stars, live in the ocean-on the sea bottoms (although their larvae swim in the water column). They are among the few groups of animals which live exclusively in marine habitats. Starfish live in all the oceans! Atlantic!
Where Are Starfish Found? ' Animals - mom.me
animals.mom.me/starfish-found-1879.html Some varieties of starfish live in the Mediterranean Sea, as well. ... Do not be surprised if you happen upon a starfish during a leisurely beach walk, as the ...
Starfish (Sea Star) - Animals - National Geographic
animals.nationalgeographic.com/animals/invertebrates/starfish/ Learn all you wanted to know about starfish (sea stars) with pictures, videos, ... years; Size: 4.7 to 9.4 in (12 to 24 cm); Weight: Up to 11 lbs (5 kg); Did you know? ... Purely marine animals, there are no freshwater sea stars, and only a few live in ...
Where do starfish live Google Search
Mar 21, 2017 | Computers & Internet
I have a 1993 mercury' marquis. The floor boads of the front part of the car get hot. And the thermostat keeps falling to c and rising to half way and falling on gage. Can u please help?! Thanks
possible no water in the engine and it is overheating
this is indicated by the temp gauge rising and falling
temp gauge sender units need to be immersed in water full time to get a reading so if it goes up that is in water and when it falls back that is in nothing or steam
hot engine would account for hot floor
Aug 14, 2016 | Cars & Trucks
440s will turn on but the screen is too dark to see
This is happening to mine also, but Garmin is saying they no longer service the item. ANY HELP out there?? You CAN see that the unit is functioning but the light level is so low you need to shade the screen to be able to tell what is happening. The slider for brightness is all the way to the right and it is not set to NIGHT view. jogging the power button does not help.
Oct 20, 2012 | Garmin GPSMAP 440 Chartplotter GPS with...
Hello. trying to locate where i "insert a coin" into the top right arm of the fisher price aquarium take along swing... can't seem to find it. help?
Do you have a pic of the battery area? I had that bouncer and if i recall its at the top but if you can add a CLOSE pic I can help.
Aug 02, 2011 | Fisher Price Ocean Wonders Aquarium Take...
Summarize how the overharvesting of a single species,a baleen whale, can affect an entire ecosystem
Different whales frequent different areas, and when they die they bring alot of energy to the bottom of the ocean where light cannot penetrate and therefore plants cannot live. A whale carcass can last for a decade and provide a meal to thousands of different creatures, like the one mentioned in the video who is specialised in eating whale bones. If no whales die, and fall to the bottom of the ocean, these creatures starve, and so, in turn, do the creatures that prey on them.
Baleen whales eat mostly krill. Krill eats algae, which is essentially turning sunlight into food.
So therefore whales are moving energy from the top of the ocean to be bottom.
Also sharks and orca prey on on a baleen whales calves, and there are fish they live in a symbiotic relationship with the sharks, like the ones that eat barnacles and parasites off the skin and gills of the whale.
utube.png You-Tube video "rdI3eFrTGs8" placeholder
Mar 09, 2011 | Toys
I have a garmin gpsmap 440s that will only read sonar depths a no wake speed. When I increase speed much past this the depth number blinks but does not track or change until I slow back down to idle again....
Sounds like the transducer is installed at the wrong angle or in such a way that it is getting a lot of air from something on the hull. If it is a transom mount, check that it is angled correctly and not too close to the motor or aft of some kind of thru-hull fitting that will cause turbulence.
Aug 18, 2009 | Garmin GPSMAP 440 Chartplotter GPS with...
Bread is falling during baking
I had this same problem. It has to do with the amount of water and the amount of yeast you are using. I decreased my amount of water to 1 cup ( of course it depends on your recipe) and I also was using rapid rise yeast which calls for a less amount (usually 1/2 tsp less than what the recipe calls for). I did experiment with the recipe until I got it just right. Good luck. Carrie
Jan 16, 2009 | Welbilt ABM3500 Bread Maker
Sonar not working properly, intermittent
Generally, that indicates air bubbles in the water under the transducer. If you have a transom-mount transducer, make sure the bottom surface is level or angled slightly down. If you have a thru-hull, make sure your bottom is fairly clean in that area.
Oct 20, 2008 | Garmin GPSMAP 440 Chartplotter GPS with...
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Games Logo
114 people viewed this question
Top Games Experts
Pamela Leach
Pamela Leach
Camryn Johnson
Camryn Johnson
Level 1 Expert
Are you a Game Expert? Answer questions, earn points and help others
