Question about Danby DPAC8020 Air Conditioner
Compressor Died on Everstar 11,000 BTU Unit
Does anyone know who may support a replacement of a compressor on one of these portable units..........or should I cut my losses?
  • sixorsoofus Jun 25, 2009
    that is what I figured..........is the life on these really less than 3 years?
  • 434 Answers
Compressors generally cost as much as the whole unit.
Posted on Jun 24, 2009
  • Mike Phillippi Jun 26, 2009
    It's hit or miss. Some will last 10 years and others only a couple. Sorry.
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
Unit will not power on. Green light on the power cord indicates it is getting power. also tried different receptacles.
If you noticed an electrical smell (like something was overheating), you may have a compressor lockup, or a fan lock. If you know a good, and knowledgeable handyman, he should be able to troubleshoot the unit quickly. But if it is the compressor, repairs could cost as much as a new unit.
Jun 02, 2016 | Everstar Portable Air Conditioner MPK-10CR
Water fill area
Compressor is working and it goes on and off. There is a air coming out, but not cold for this 11,000 btu. I also need a longer exhaust hose. Please advise. Unit works great when functioning.
Aug 04, 2012 | Amcor A12000E Nanomax Portable Air...
I have a everstar 10000 btu portable ac and the compressor died in it. i want to take it apart to recylce but not sure how to safely remove the freon inside of the system. plz help
Most people can not remove the ref. properly per. (EPA) you would need a tap fitting and guages and a recovery unit to transfer the ref into a tank. Take it to your land fill and they will charge you for this and its the responsible way to dispose of it.
Jul 05, 2011 | Heating & Cooling
Have a portable everstar ac model MPM2-10CR-BB6 blow strong but no cold air.
check temperature setting and the mode on cool if ok check the compressor is working with condenser fan if are working the unit has a loss of refrigerant . if the compressor is not working and voltage is correct may be the capacitor need replacement
Sep 03, 2009 | Heating & Cooling
Everstar portable ac 10000 btu
The everstar 10,000 BTU unit will require a dedicated 115 V 15 amp circuit. if there are other things pluged into outlets and running from the same breaker then the 15 amp breaker will trip. Or, these units also have a GFCI plug adapter. Be sure it has not been tripped due to an improperly grounded outlet, or wet location.
Aug 22, 2009 | Heating & Cooling
Demby portable Capacity: 11,000 BTU air conditioner
This unit is sized to approx a 35 square metres area at a normal 2.4 metre ceiling height. All I would recomend without actually seeing the problem is to check this measurement and close all windows and doors. The unit is most likely undersized, but check the air temp coming off the unit. It should be about 10 degrees.
Aug 15, 2009 | Heating & Cooling
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Where do I find parts for everstar portable air conditioners
I just purchased a 11,000 BTU Everstar from Home Depot. Not sure if it's the same model that you have. Maybe check there? I bet an employee would be willing to open one of the boxes to answer your question. Just tell them you bought it there. :) Or call Everstar, of course. Good luck!
May 31, 2009 | Whirlwind FH-778 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
174 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
