Question about Microsoft Windows Vista Ultimate Edition
How do i disable autorun Microsoft Windows_7?
  • 26 Answers
These are the two main alternatives to disable the autorun in windows 7:
1. Using the control panel, navigating to hardware and sound, and uncheck "Use Autoplay for all media and devices"
2. Using the Microsoft Fix it 50471 as explained here:
http://support.microsoft.com/kb/967715
Posted on Jun 04, 2014
2 Suggested Answers
  • 108 Answers
SOURCE: i have a microsoft windows 7 ultimateCD.I 'am
It sounds like you are attempting to upgrade to windows 7 within an earlier version of Windows, and are having an issue with the earlier version missing files. The Autorun.dll file belongs to a component within windows responsible for automatically launching a program from a CD, once the disc is inserted.
My suggestion would be to back up all your files to a disk, boot with the Windows 7 CD, and perform a clean re-install (completely removing the previous version). You may be required to provide the CD product key belonging to the older version of windows you have, as well as the key for the Windows 7 disk. Or you could attempt to locate the disk you used for installing the previous version of windows you possess, and using the "repair" option. in both cases though, make sure you back up your files!
Posted on Dec 25, 2010
Tip
How to remove Autorun.inf
Here are some typical malware which can install autorun.inf.exe file to your computer and give your computer a critical strike.
Autorun.inf virus contains three execute files which are kavo.exe, ntdelect.com and autorun.inf. All of them are hidden files. You cannot find the by showing hidden files. The only way to find them is to use DOS command.
Not all user have computer savvy. I was suffered from this virus a lot. Success got rid of it using RegTool and want to share it with you.
To remove Autorun.inf
Tools you need RegTool and AVG anti-virus.
Also here is an easy way to remove Autorun.inf manually!
click Start>Run>enter “CMD” them you will see and command window. In the command prompt, you can search for any exe.files. First we can disable “read only” and “hidden” attributes.
Enter the word in prompt.
Check C drive: key in dir c:\/a/w
2 then
attrib -s -h -r c:\autorun.inf
attrib -s -h -r c:\ ntdelect.com
You can use the same way to disable attributes of other drive such like D, E, etc.
3 OK, everything is done, we can now remove these two files.
For C drive, you can enter
del c:\autorun.inf
del c:\ntdelect.com
The same to D drive
How about kavo.exe? You need to repeat step1 and step 2 to disable attributes.
The delete command is different with them.
attrib -s -h -r c:\windows\system32\kavo.exe
del c:\windows\system32\kavo.exe
last thing you should do:
Open registry editor by entering Regedit.
Go to HKEY_LOCAL-MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Remove Kavo value.
on Jun 01, 2010 | Computers & Internet
My seagate freeagent goflex 1tb hdd appearing as local disk in my computer... the autoplay dialog window doesn't come up when the drive is connected..
AUTO PLAY DIALOGUE IS OFF IN YOUR OPERATING SYSTEM
ENABLE AUTO PLAY
WHAT OS YOU ARE USING
OR CHECK BELOW LINKS
Windows 7, Windows Server 2008, Windows Vista, Windows Server 2003,or Windows XP
Fix it for meTo disable or enable Autorun automatically, click the appropriate Fix this problem link. Then, click Run in the File Downloaddialog box and follow the steps in this wizard.
Disable AutorunEnable Autorun
Fix this problem
Fix this problem
Oct 29, 2013 | Seagate FreeAgent GoFlex Desk - 1 TB...
Delete autorun inf virus 4gb
If you have a autorun.inf virus on your memory card/USB stick the anti virus software on your PC may not allow access in order to stop it from spreading.
First you need to disable autorun feature on Windows operating system :
Follow steps in link :
http://www.redmondpie.com/how-to-disable-autorun-autoplay-in-windows-7-and-windows-8/
After disabling the feature you will have access to your memory card/USB stick. The next step is to delete autorun.inf virus file hidden on your memory card/USB stick. But first you need to make the hidden virus file visible.
Follow steps in link to show hidden system files :
http://www.bleepingcomputer.com/tutorials/show-hidden-files-in-windows-7/
Now navigate to your memory card/USB stick you should see the autorun.inf file - DELETE IT.
(If it doesnt allow you to delete it - restart the PC in safe mode by pressing F8 on start up and choosing safe mode and try again)
Back up your files on the memory stick/USB stick to your PC and to make sure the virus is gone from the memory stick/USB format it using your PC.
Dont to forget re-hide your system files to prevent accidental deletion.
Oct 15, 2013 | SanDisk 1GB microSD Memory Card
I have Samsung R590 Laptop which i bought December last year... Before the USB ports used to work properly and display wt ever data is present in the usb ... but now it reads the data but all appear as...
Microsoft Knowledge Base
Article 971029
describes an update to Autorun that restricts AutoPlay
functionality to CD and DVD media. This update is intended to stop AutoPlay
functionality from working on USB drives, external hard drives, or network
shares. This update is available for supported editions of Windows XP, Windows
Server 2003, Windows Vista, and Windows Server 2008.
Removable USB/thumb drives use the Autorun feature to load files when the drives are plugged into the USB port. Malware exploits the Autorun feature to spread from thumb drive to PC. Disable the autorun feature to prevent malware from spreading.
The preceding describes what has likely happened to your USB ports due to Windows update disabling the autorun feature for USB thumbdrives. The thumbdrive may no longer present its data properly unless you manually invoke the autorun in its root.
Mar 27, 2011 | Computers & Internet
When i insert a autio CD or dvd aurorun does not reconize any
The registry key HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer can be used to enable/disable AutoRun:
Variable............................................................. Number............Hexadecimal
No autorun at all..................................................... 181............... 0xb5
Autorun only CDROMs................................................... 149............... 0x95
Autorun only flash drives..............................................177............... 0xb1
Autorun CDROMs and flashdrives (the default starting from XP SP2)......145................0x91
You can also go to HKEY_LOCAL_MACHINE... and change it to 149 as well
Meanwhile you can Right Click the CD/DVD drive and click Auto Play
Sep 08, 2010 | Computers & Internet
Usb port does not detect autorun
Okay in XP
  1. Open Windows Explorer by pressing the Windows + "e" key.
  2. Right-click the desired CD-ROM and select Properties from the menu.
  3. Select the AutoPlay tab.
  4. Select each item from the pulldown list and for the Action to perform, select "Take no action" to disable autorun, or pick the apporpriate action to take if enabling autorun.
  5. Select OK.
Ryan Frame
Creative Energy Associates Technical Center
Apr 29, 2009 | Microsoft Windows XP Professional
Microsoft Windows Vista Ultimate Edition Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
