Question about Acer X193W LCD Monitor
My monitor acer v193 can't be open
My monitor acer v193 can't not be open
My ACER Monitor shows green striped pixels wherever there is BLACK colors on the screen. Eg: Shadows in a video game, wallpaper with black background. It happens on and off, but the more it happens the...
The problem is either the video graphics card in the computer or the monitor, if you have a backup monitor check the computer first, if the same problem persists the video graphics card is bad. If however the second monitor is fine, then your monitor is the problem, The screen is breaking down, if you have a detachable video cable, sub it for another to make sure there are no issues,if okay your monitor is the problem and not cost effective for repair.
Jan 03, 2011 | Acer V193 Monitor
Will not come on, have had it almost 2years, is the warrented still good
The Acer V193 series has a three year warranty. Go to www.fixmyacer.com to have your unit repaired.
Nov 19, 2010 | Acer V193w LCD Monitor
I have an Acer AL 1914 Monitor. Green light
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 26, 2010 | Acer AL1914 19" LCD Monitor
What can i do if my acer lcd monitor haven't power
May 19, 2010 | Acer AL1917W LCD Monitor
Sreen goes off then on then off ??
check capacitors inside, or solder loose contact on power supply board
May 06, 2010 | Acer V193w LCD Monitor
How to open acer lcd monitor model no AL1706A
gulabgoud, Most monitors come apart the same way, or almost!!! May I suggest that you visit YOUTUBE to search and view some video clips of VALID (good) "lcd monitor disassembly" and / or "lcd monitor repair" ??? Have you ever heard the expression "a picture (in your case video clip) is worth a thousand words" Good luck guy, your on your own!!! If this helps you out, please rate this response on fixya. But don't come back here CRYING or complaining IF YOU SCREW UP YOUR MONITOR !!! Bye for now.. 12fix louie
Nov 13, 2009 | Acer Computers & Internet
I live in Seattle and have an Acer V193B that 'went dark' when I hot-pluggged the VGA connector into my laptop. I *assume* the problem is the chip that buffers the VGA lines is blown. (I know the cable and...
maybe a short circut happened and fried your monitor's decoding unit... There probably is nothing you can do to fix it and you can't really do anything with it other than trashing or potentially expermenting with the thing, but bewarned, It may jump back to your laptop...
Oct 01, 2009 | Acer V193 B LCD Monitor
ACER LCD Monitor
put it face down (over a clean soft cloth) and start loosing all screw, after this with a swiss knife on the edges, start loosing the plastic with patience... always unplugged...
Sep 17, 2007 | Acer AL1511 15" LCD Monitor
Acer X193W LCD Monitor Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
