Question about Dewalt Drills
How to removing / replacing brushes in DeWalt DW929 cordless drill with rs-775vc-9511 motor?
Model DW929 series 1 with rs-775vc-9511 motor.
rowdy45176
  • 2176 Answers
SOURCE: Unable to get to brushes on DeWalt DW959 drill type 1.
the brushes are made to slide into the side of the motor. gently pull up on them. Also I would recommend that you go to Dewaltservicenet.com and type in your model number for a parts explosion and part number for replacement brushes. Let me know
Posted on Jan 11, 2009
  • 103 Answers
SOURCE: Ryobi cordless drill burning smell
your over using the drill on havy jobs
Posted on Apr 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: cant figure out how to remove brushes
go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number and it will take you to a page so you can bring up a schematic on this tool. let me know if you need any more help
Posted on Jun 10, 2009
  • 115 Answers
SOURCE: dewalt dc759 drill squealling noise coming from
yes,the most coomon defect for poer tools are carbon brushes.But,git attention also to the gears,bushings, and bearings if there are loosen parts.Also you get rid to a debris or any small dirt particles that maybe sunctioned by the fan and has been entered in the body of the drill thats why you can hear an squealling noise..Just open and clean it.
Posted on Dec 05, 2009
tcraignfam
  • 30 Answers
SOURCE: DeWalt cordless drill DW926. I can't get the
Turn your drill speed selector to "1" and put drill direction in reverse. Hold the outer end of the chuck and push the trigger. Should come loose.
Posted on Dec 12, 2009
Testimonial: "Perfect - thank you!"
How to remove brushes in a dc759 drill?
you cant replace the brushes on this drill it is a sealed motor. go this site the replacement motor is $ 38.77 http://www.ereplacementparts.com/dewalt-dc759ka-type-18v-cordless-drill-parts-c-1009_
Jan 20, 2010 | Dewalt 18v 1/2" Compact Drill/driver Kit...
Dewalt cordless 12v drill, 3speed model...spinning problem
Sounds like your brushes are either damaged or the armature is failing the current. Remove the brushes first and inspect them, that is where your arcing is coming from. If the brushes appear ok, your problem is in the armature itself. Regardless of low use, if you store the unit with the battery attached, there are issues with the current draw while stored.
Jan 17, 2010 | Garden
I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
Dec 21, 2009 | Dewalt DW056 18 Volt Cordless Impact...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
14.4v dewalt xr2 drill
Some cordless Dewalt drills do not have open motors allowing access to the brushes. However there are a few styles that do.
If you want to check, open your drill. Remove the screws from the housing. Then remove half of the housing. You can see the motor at the back of the tool. If there are vents at the back of the motor you may be able to see the brushes the removable type are connected to a gray or tan piece of plastic mounted at the back of the motor.
If the brushes are from a removable style you can purchase a brush set. If they are hidden in the motor. You will have to change the whole motor.
You can check the Dewalt Service Net web site to find out.
Apr 20, 2009 | Dewalt 18 Volt Compact Drill Kit
Jan 11, 2009 | Dewalt heavy - duty 1/2" 18v cordless...
Hello, I have a dewalt drill cordless 12V. I have taken the casing off and want to know how I want to know how I get to the brushes. It has stopped working and suspect that it is the brushes. I am not...
I fix cordless DeWalt drills every week!Look for two black carbon-like blocks found on either side of the commutator ( the central spindle ) they will each have one wire on the outside end attached to a spade connector so the brush can be easily removed by prying it out from beneath the spring holding the brush against the commutator.  Then the wire can be removed and the new brush installed.    Go online to http://www.toolpartsdirect.com and search for your model dewalt drill. they have an exploded diagram and parts listing for each model drill.  That will identify the brush for you if you have never seen one before.    If the drill was operating intermittently with lots of noise and usually blue sparks coming out, loss of power, increasing intermittant operation it would almost certainly benefit from replacing the brushes.   If it is simply dead, and was ever dropped.  check the battery terminals and the trigger mechanism.  Of course inspect the battery and check inside the drill for loose or broken wires and connections. I hope this is helpful. Good luck!
Dec 11, 2008 | Dewalt DC727KA 3/8" 12v Cordless...
Dewalt DWo56 18 Volt cordless impact
all drill has brushes. this particular drill you need a motor assy
or switch. vibration & heat are common problem cu'z the drill not to properly
Mar 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Drills Logo
334 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
