Question about Ionic Pro TURBO Air Purifier
Why it stop cleaning air? - Ionic Pro TURBO Air Purifier
Honeywell 50150 stopped filtering the air
If you are recycling the filters then they could be totally plugged up.
Mar 03, 2014 | Honeywell Air Purifiers
Unit stopped working
I have the same problem. Cleaned filters, lights were never on to indicate they needed to be cleaned but i cleaned them anyway. Tried resetting lights by holding 10 seconds and nothing.....
Aug 07, 2012 | Honeywell 50250-S True HEPA Air Purifier
How to Clean electric motor in air purifier
replce the mtors as there is nothing in them to clean
May 23, 2017 | Air Purifiers
Ionizer wires get dirty
IT'S THE NATURE OF THE BEAST. IF YOU TRY A ANTI STATIC CLEANER THIS MAY HELP .. JAY THE POOL PUMP REPAIR GUY FLORIDA
Feb 03, 2012 | Honeywell Enviracaire Elite F300E-1019 Air...
No matter how much I clean the machine after it is turned on for 10 min or more it starts to buzz and make a static noise, any other suggestions?
The buzzing noise is not from dust in the air purifier, it's from the dust and pollutants in the air, it's now picking up. It should stop once the air is cleaned.
Apr 17, 2011 | Ionic Pro TURBO Air Purifier
How do i stop the red lite for the collector cell to stop blinking ?
By changing the Collector Cell. The flashing light is an indication that it needs cleaning.
Here is a link to model you listed above. It has all the information you need, on how to clean the Collector Cell. You can download and print it for future reference.
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Hope this helps you solve the problem.
Mar 21, 2011 | Oreck XL Professional Air Purifier
Ionic breeze s1867 stopped cleaning
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Aug 09, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
My Ionic Pro Turbo air purifier is blowing air in intervals of 30 seconds, blows for 30 seconds then stops for 10 sec. then repeats. Is this normal or do I have a defective unit? Thanks, Jerry
Have you cleaned the unit good and made sure that there is nothing crossing the grid wires? It sounds as if it is cutting off and resetting for some reason. Mine runs continuously. I take an air compressor and blow mine out every time I clean it. Also, on some models, you have to hold the on button down for several seconds to reset it after cleaning. Hope this helps.
Jul 03, 2009 | Ionic Pro FULL-SIZE Air Purifier
My pureion makes a crackling/ticking sound when running;
Its just a wear in the ozone plastic its normal after continued use
Mar 22, 2009 | Brookstone Pure-Ion UV Air Purifier
Ionic Pro TURBO Air Purifier Logo
70 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
